Piston slap......
Old Jul 8, 2005 | 04:03 PM
1Bad00SS's Avatar
Default Piston slap......
Is there any certian piston or is it random. I ask cause I have a tapping noise coming from the back piston on the pass. side.
So I guess my ? is: what is more common from missing gears or over reving piston slap or a bent rod cause thats the only thing I think I've done is over reved and missed a few gears.
the more imput the better.
Thanx James
BTW the car has 54xxx miles on it
Old Jul 8, 2005 | 04:07 PM
Country Boy's Avatar
can survive...
you cant over rev by missing a gear unless you down shifted on accident (mechanical over rev). If thats the case, you likely have a bent pushrod. Its very common on an over rev... also, so are bent valves.
Old Jul 8, 2005 | 04:09 PM
1Bad00SS's Avatar
I did go from the top of 2nd into 1st but once I felt it grap I knew it and pushed the clutch in.....
Old Jul 8, 2005 | 07:32 PM
myltwon's Avatar
Bolt-On 2v GT
also like I said the ticking noise could be a ton of things
wire arching, exhaust leak, low oil pressure(causing valvetrain noise), etc
do the screw driver test I told you about you lazy mofo and also check all the plug connections
Old Jul 9, 2005 | 08:16 AM
formula69's Avatar
blowed up
check bolts in exhaust manifold..
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Jul 9, 2005 | 12:42 PM
gator's Avatar
Underdog
whats piston slap?
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Jul 9, 2005 | 12:45 PM
myltwon's Avatar
Bolt-On 2v GT
guess he found out it was a bent pushrod
Old Jul 9, 2005 | 12:47 PM
fathead's Avatar
I'm aLL mOtOr I sWaRe ;)
maybe a spun rod??? or do domestic guys not get that?? that can happen shifting 2-1...
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
Old Jul 9, 2005 | 01:11 PM
WhiteHorseGT's Avatar
Love you Kev-Dawg!
most likely a bent pushrod....common on ls1's i heard
RIP Kevin Slo_Si
You will be missed brother
Old Jul 9, 2005 | 01:32 PM
shalane's Avatar
TR Balla Donor Supreme
take it to a dlr and have a diagnosis... tell them you want help
what mods do you have
