Auto trans stuck in reverse/park?
Old Jun 24, 2005 | 11:09 PM
Default Auto trans stuck in reverse/park?
Approaching a traffic light, I moved powerglide auto trans into
neutral, coasting to a stop, as I have done thousands of
times.
It felt like it went into park, and rear tires screeched. At first
I thought I had moved the shifter too far. I couldn't push the car
at all, but rocked it a few times forward/back..........
Something loosened up and it was pushable.
It also became driveable, but only in reverse. No problem.
Drove it off the road in reverse and into a parking lot.
Thought maybe the trans mount had broken, and the
shift linkage was now; not "long enough" to put trans
into drive.
I unbolted the shift linkage under the hood at the
steering column, and physically pushed the linkage downward
where drive would be. I could feel the detents gripping
as it went through the gears.
I bypassed the "don't start switch" and started the
engine in drive, since I couldn't work the unbolted shift rod.
The car moved about 6 inches forward,
and abruptly stopped as if it had jumped into park.
Tried starting in drive a few more times....car moves
about 6 inches forward and stops abruptly as if it had
jumped into park.
It's driveable in reverse, but that's the only direction.
When I try to put it in drive, it moves about 6 inches and jerks
to a stop like it was just put into park.
Can anyone suggest what I should look for? I thought about
removing the trans pan and seeing if something got hung up
in two places at once,.......but yet it will still go into reverse......
.....so I don't know.....Any ideas?
Old Jul 2, 2005 | 07:19 AM
times.
into drive.
jumped into park.
So does anyone know any auto transmission theory?
Old Jul 2, 2005 | 07:35 AM
Notladstyle's Avatar
King of Ricers
I always wondered if pulling a moving car out of gear harms the tranny, Ive had the same thing happen to me with the shifter getting stuck but i just slammed on the gas and it started rolling again - but then again I have a deathwish and a b2b warranty
notladstyle.blogspot.com
Old Jul 8, 2005 | 11:13 AM
You can be sure it won't be driven....since it only drives in reverse.
Eventually I'll get the pan off and see if something looks hung up.
Working on my daily driver right now....
Originally Posted by Fordified
Something is definitely wrong, but I don't know enough about the inner workings of a Glide to tell you where to look. Either way it sounds like the tranny needs to come out of the car so I wouldn't go trying to drive it anywhere and fuck up a tranny that is becoming rare.
