97 s10 v8 conversion need help
Old May 22, 2005 | 08:29 PM
Na306StAnG's Avatar
Flowmaster nut swinger
Default 97 s10 v8 conversion need help
97 s10 v8 conversion has any one done this i have a 97 with 2.2 4cyl with the 4l60e tranny i want to put a 350 in it how hard is it i have an asortment of big fucking hammers and iam sure iam going to need them let me know how bad its going to be
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old May 23, 2005 | 06:06 AM
gator's Avatar
Underdog
go onto revxtreme.com and ask this or any V8 s10 question. they have a guy running 9s with that combo.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old May 23, 2005 | 06:11 AM
Na306StAnG's Avatar
thanks and nice trans am in your sig badass looking
not looking for a 9 sec truck just more power then the 50 my 2.2 it putting out thanks again
Largo fl 33773
MV#72427
Old May 23, 2005 | 07:18 AM
Young,Fablous,&Broke's Avatar
Putting a 13 second block and putting a 9 second block is pretty much the same deal.
Old May 23, 2005 | 07:59 PM
DANGERANGER's Avatar
Shop Bitch
Fairly easy swap as compared to the Ranger swaps. Mostly factory parts from a 4.3 will work. Get a aftermarket harness if running a FI engine as it would save you time and agitation if you've never decoded the factory harness. makes it plug and play mostly.
Frank
Enhanced Concepts
727-638-4667
Old May 24, 2005 | 07:26 PM
mustangnick88's Avatar
I am just getting into this swap myself except I am using a 5-speed. I know my shifter won't line up, crossmember, and some stuff for the clutch cable. This is all things you won't have to deal with. From what I have read 82-97 are almost the same. Same motor conversion parts. I was going to go with a vortec350 and keep it fuel injected with a plug and play but I got a 350 pretty much for free and just going to rebuild it and go the cheap way with edelbrock heads, intake, and whatnot. good luck
Old May 24, 2005 | 07:38 PM
myltwon's Avatar
Bolt-On 2v GT
I want to do a 350 swap car/truck next
Old May 24, 2005 | 08:08 PM
Na306StAnG's Avatar
Thanks for all the info
best thing happend today. it was around 2:30 and made a run to autozone (starkey and eastbay). luck was on my side a 96 S10 looked like a clone of my truck but it had draglites on it i have pro stars. he already did the swap no beating of the fire wall none of that. he even drove it back to my shop so i could get pics of it for future reference. seams to be a simple job his truck was fucking nasty also 350 trick flow heads soild roller 630 630 and a 150 shot of Nitrous. truck was hooked the fuck up. thanks again
Largo fl 33773
MV#72427
Old Jun 4, 2005 | 07:33 AM
awesome. Now I just need to finish putting my motor back together. My setup is 350 with edelbrock performer top-end back by a freshly rebuilt T-5(yes I am scared it will break shortly after breaking in the motor). I never had any luck with a t-5 in a mustang with a 302. I guess I'll see how lond it can withstand 350-400 horse. lol. good luck and I am happy everything fits in.
Old Jun 7, 2005 | 06:59 PM
SAPPER's Avatar
check out http://www.v8s10.org/forum/index.php good luck with swap
