no power from a complete stop
my car is at it again, it's got perfect power all around, but it seems like
from 0mph it has almost like a turbo lag feel(no power til the rpms
get higher) I can't break the tires loose even if I stall it up to 1500rpm, but if
I punch it from 20-30mph it fucking hauls and chirps the tires between gears.
quick question can a noisey engine compartment cause my knock module
to pull timing and would it cause similar symptoms like this?
ok EGR is fairly new, 5k miles
TPS is new, like 4k miles
converter(if talking about cat and not torque) is gutted
not throwing any MAF codes though
as for the tranny, even if I drop it to 1st gear manual, and it does
down shift, the result is still the same
the idle is fairly good, slight "bump" every once in a while in the idle,
nothing major, occasionally idles too high though, and tranny will kick
into gear extremely hard. also when this problem occurs, power loss is
extremely noticeable at any speed.
I'm thinking this is sensor related, I.E. knock module, map, tps, maf
though since the aforemention problem occurs randomly, every once
in a while.
my engine bay is fairly noisey decent sound of clicking, doesn't sound
like a rod knocking though, more like a slight tick, and my exhaust is
fairly loud so I figure maybe my car is pulling timing somewhere.
like stated before the power loss only really occurs from a complete
stop, if I punch it from 10mph+ power is normal and the car will
perform well.
also my car will occasionally click/pop a few times under the hood before the
tranny shifts from and will hold the gear longer than normal.
also as for the neutral revving it seems to rev perfectly normal, no hesitation whatsoever
also this pic seems to describe my problem in the definition
in a while.
perform well.
O2 sensor. i bet your gas milage is suckin right now too.,
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
ok here's a clip of my car, looks like it's running a little rich....opinions? http://videos.streetfire.net/Player....rmula&t=browse
fairly warmed up
oh man time to dive in, gonna change the plugs and the passanger o2, because the driver side one is still only 3-4 months old
I wanna know what this can mean
