Modified 400ci plus block out of a 76 Trans Am..
Old Apr 20, 2005 | 10:55 AM
76TA's Avatar
Got ahold of the original owner - Below are specs as provided by him. The Carb descrip is now inaccurate - It's a 400 series. I don't know what (if anything) else has been changed in the interim
Block is 1973 model.
Main bearing caps were line bored,
High perf cam & main bearings,
Cylinders bored 60 over,
Moly rings(all were filed to have the same air gap), Pistons & crank were balanced, pistons were measured & then cylinder hole was bored to fit each piston, each piston is numbered for the cylinder it was in.
High performance Melling oil pump.
TRW double roller timing set.
Camshaft was stock RAM AIR III.
Lifters were high perf Melling.
Heads:
Supposed to be 68 RAM AIR III,
Intake valves are 2.11"
Exhaust valves are 1.77", all were swirl polished.
Valve guides were bronzewalled.
Rocker arms are RAM AIR III, 1.65:1 ratio, which increases valve lift .050".
Rocker studs were from big block Chevy, 7/16"
Rocker nuts were from big block also.
All intake & exhaust ports were polished & gaskets matched.
Edelbrock intake manifold with Holley 750 dbl pumper with everything manually adjustable.
Transmission is short shaft turbo 400.
All B & M trans parts used. Somebody took off the pan, it was a deep pan that used a Chrysler filter.
The exhaust manifolds & muffler were stock from 1974 model.
Old Apr 20, 2005 | 11:00 AM
Ian MMF's Avatar
Omnipotence
Do you plan on selling the transmission with it also? I noticed you posted the info on the turbo400 also.
Old Apr 20, 2005 | 11:51 AM
76TA's Avatar
Bad edit - but I could I be convinced. My ultimate goal here is to commit Pontiac sacrilege and put either an LS1 or LS6 engine in the car - something fuel injected yet still a worthy engine for it's heritage. I bought it for the body (I love the body style) and my plan is to make it modern.
Old Apr 20, 2005 | 12:50 PM
myltwon's Avatar
Bolt-On 2v GT
putting a cheby in a poncho
Old Apr 21, 2005 | 12:32 PM
76TA's Avatar
Unhappy
Well, it's the 00's now - it's a corporate world.. and Pontiac doesn't make engines.. anymore.. So I'll use an engine that goes in Pontiacs.. The last TA's had LS1's and the the current Roo's have LS6's. FWIW, I think my father in law is on your side though, I think he's gonna try to convince me to keep the 400.
I myself am not a purist. I do think the heritage of the car should be noted and acknowledged (I never understood how Pontiac could lose the Chicken from the hood) But I don't think nearly 30 years of technology should be ignored to keep the car like it was in 1976, either. This particular car is the original precursor to the ever famous "Bandit" model of '77. Black and Gold with all the striping. it's a 50th anniversary edition. All the exterior will be restored pretty much original. I may add a stripe along the sides to break up all the black. As far as teh interior goes, It's will get a complete re-do. The stereo sucks, the comfort is terrible, the seats are a whiplash lawyer's dream, and the creature comforts (cupholders, things of that nature) are.. uhhh.. lacking.
So, I my goal is to modernize her. Mechanically as well as the cockpit. In the cockpit, I want to keep as many of the styling cues as possible, bring in some modern seats with headrests. I do kind of want to stick and 8-track player in her though, she had one originally and I think that's kind of twisted and funny, see how many people go "what's that?" when they see it. Add modern creature comforts, and so forth.
So, cheby or chevy, tomayto or tomahto.. As a middle age guy, I don't see the point in ignoring the advancements of the past 30 years. I don't disagree with the purist point of view, either, I believe there's a place and a strong argument for keeping cars original. It's just not mine.
