ECU eliminate gov?
Just curious, does a performance chip eliminate the top speed sensor? because i want to purchase a jet performance chip but not unless it eliminates the sensor. can anyone help?
dont waste your money on a JET chip. have your chip burnt to your custom specs by a tuner. i believe Jeremy Formato can do this. he is usually at Rev Xtreme.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
you have a 4.3 or 2.2? if you have a stick- you can tap into the VSS wire (yellow) under the shifter by the tranny, an out a toggle switch in there , your speedo guage wolnt work but you will be able to go over- i dotn reccomend it but, you can do it that way, ive heard that the jet chips dont work, mike
VSS is a good way to get yourself in trouble....
The speedo won't work, the odometer won't work (can we say odometer fraud? weee...) and your car goes into limp home mode.
You could do a standalone system. That's about the only real fix for it.
since when does a car go into limp mode with a faulty VSS? i have never heard/experienced this.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
your truck does not go into limp mode, at least on the s-10s ive sseen it done on, yea the odometer dotn work, and your speedo does not work, but it Does bypass the speed limiter, but if your rolling on stock tires, or in a 2.2 i dotn think you should do it, the factory tires are only rated to around 96 mph, mike
your limiter is not like a resitrictor plate hoss....its electronic. and new tires doesnt mean anything?
honestly, wtf are you doing that you are going that fast..and in a timely manner.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
turning my truck into a sport truck. i usually drive long distances and i hate going under 95 all the way there. that and i am going to put a v8 in it, and since its all electronic, i need to change it or my engine will be gone
