2 more LT1 Questions...
I need a tune up done...im taking it to someone to change the plugs and wires since im not gonna deal with that bullshit pain in the ass job. anyways, what is the best plug wire combo, for the price, running all stock, no mods other than K&N air filter, and i will soon be replacing the whole air intake with a better one, but other than that its all stock. just looking for what the car will best perform smoothly and react to reliably.
also, does anyone here know how to get the fans to turn on at a cooler temp?? 226/235 for the fans to turn on is unacceptable. i need them to turn on at 200 or less.
The wires are really up to you, MSD makes a really good set and so does ACCEL.. I would go with the Accel, because i have had problems with the MSD 9mm in the past..
As far as the plugs go, i have run NGK V-powers for years, they are an excellent plug, especially running down the track under a 300 shot of nitrous!!
SVT F150
SVT F150
yea, you need the TR55's or equivalent (stay away from autolites) and go with a stock sized wire, if you go to 9mm, i dont think they fit in the holders to route them.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
8.5 or 9mm are more of a pain to route and yeah they dont fit the stock looms.. plus u dont need thicker ones. the AC delco stock plugs are actually better than most. I tested spiral, taylor and AC delco had the least resistance and really no arcing problems to them.
Get a 160 thermostat and have your fan setting at 180.. Thats a common set up and works fine.. its what i use... Had for 25,000 miles and pull the engine out and no abnormal carbon build up like some fear having that low of temp.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
If the cars stock just run factory wires so they fit in the factoy holders to keep the off the headers. Or you end up burning wires all the time from them laying on the manifolds.
AIM: Boost113
New best time @ Jennings 1:25.4
AIM: Boost113
anyone with a hypertech for obdI or any one with a program like tunercat or LT1 edit on their laptap.
revxtreme can do it for u.
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
going to need to find someone with a 95 like yours then if you dont wanna go to a shop. 95s have the obd2 connector crap for the obd1 computer.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
