Clutch Preference?
Old Feb 15, 2005 | 11:34 AM
GTman85's Avatar
KBizzzle
Default Clutch Preference?
What would you guys suggest for a clutch for my 94. This stock 1 is close to its death. Kinda bad on the dyno,but pulls hard with acceration and NO slipping. As far as bang for the buck, what would be my best bet?
^^Makes me warm and fuzzzzy
Old Feb 15, 2005 | 03:25 PM
myltwon's Avatar
Bolt-On 2v GT
z06 clutch?
you don't want to go too heavy duty because then shifting becomes kind of a pain and they have a shorter live(from what I've heard)
Old Feb 16, 2005 | 06:21 AM
F*r*a*n*k*e*i's Avatar
I rock a Centerforce clutch in my '67. It has a very light disengagement, but it has these neat centrifugal weights on it that increase the spring compression as the clutch spins higher RPMs. I've had no problems with it and my knee is very happy with the light spring at idle
Old Feb 16, 2005 | 05:02 PM
formula69's Avatar
blowed up
zo6 clutch will not fit on an lt1... go with centerforce dual friction.. i just got mine put in and it rocks..
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Feb 16, 2005 | 07:41 PM
formula69's Avatar
blowed up
if your planning on gripping with a 75 shot and the bolt ons you have you will have a lot of torque behind you (over 400ft lbs) you can get away with a spec stage 2 also but if you plan on upgrading you should go with their spec stage 3.. they make awesome clutchs but streetability is limited... also life is shorter... honestly i go back to my previous statement.. get the centerforce dual friction clutch.. it is perfect for street and occasional strip use... it will withstand your 75 shot and then some and it is very driveable you wont be dissapointed
im FAT!!!!
Old Feb 17, 2005 | 06:39 AM
Yeah, I was able to run a 350hp 327 to my Centerforce for forever and it still grips like a bastard. I think I've had this clutch in my car for like 2 years now and it still grips strong as hell.
Old Feb 19, 2005 | 03:52 PM
BlackZ28's Avatar
ppssshsshhhhhhh
what are ur hp goals? if ur car is gonna be under 350-400hp, get an lt4 clutch. at autozone, the lt1 replacement clutch they have is exactly the same as an lt4 clutch. costs just less than $200. if ur looking at over 400hp, check www.camaroz28.com they have lots of info on all the different clutch sets
Old Feb 26, 2005 | 07:00 AM
dead-98-LS1's Avatar
spec stage 3 all the way
Old Feb 27, 2005 | 02:45 PM
BDIX's Avatar
Dick is Huge!
I wouldnt reccomend a spec for daily use...
Totalled his shit!@
