Overheating???
i have a 95 camaro Z28, wondering....for those that have the same car/engine setup, where does your temp needle sit....
when sitting in traffic
idleing/not moving in park
driving
driving
driving
driving
-Vince
-Vince
I was thinking the same thing when I first got my car. Let me put it this way - your fan doesn't kick in till about 238 - I can't think of any other common engines that run as hot as F-Body engines, they're built to handle the heat, and I've been told that heading the engine so high is quite good for it, as it burns off buildups from the valves and runners and whatnot.
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
It's because your fans are on the stock settings.
Don't turn off the A/C in traffic, as long as it's on the second fan will be also. Have your fans reprogrammed and a lower temp thermostat.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Richard
Mostly stock
1998 Camaro
get ur pcm reprogrammed. stock fan settings are pretty high. my car used to run hot like that all the time too. ever since i did the pcm and 160 stat, it runs cool as hell, even when its hot outside. http://www.madz28.com/
Don't get the wrong idea about this, man. Its healthy for the car to run at those temperatures, and actually not that good for it to run on a 160 degree thermostat. I mean, its like it is for a reason - and that reason is usually reliability over performance.
LT1's are set to run at those temps for emissions reasons only. The LT1 was an evolution of the SBC. AL heads and reverse cooling that flows from the radiator to the heads to the block. The purpose of that is to be able to run a higher compression ratio with out detonation. Getting a properly prepared LT1 to run on pump gas with 12:1 CR can be done with no detonation.
