lt1 vette 94-96
Old Jan 18, 2005 | 07:52 PM
kender's Avatar
gadget man
Default lt1 vette 94-96
any good places around here to get an lt1 vette 94-96 with tranny ecu and wiring? preferably in the counties surrounding the tampa bay but I am willing to travel a little for the right swap. thanks
U.S.S.A Crew Member #001
Old Jan 19, 2005 | 02:55 AM
Gunslinger09's Avatar
Devils advocate
www.car-part.com
And why does it have to be a Vette Lt1? You could probably do it for cheaper with a Fbody Lt1.
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
Old Jan 19, 2005 | 05:34 AM
kender's Avatar
gadget man
this is for an 80 elcamino and the camaro lt1 has problems with the oil pan and the cross member wanting to occupy the same space, as well as the a/c compressor. the vette lt1 is supposed to be the only lt1 that I would drop in without clearance issues.
Old Jan 19, 2005 | 08:59 AM
onesweetZ06's Avatar
Just buy a LT1 vette oil pan
Old Jan 19, 2005 | 01:28 PM
kender's Avatar
gadget man
I would assume, by your suggestion, that the oil pans are the same bolt pattern? and that the internal pickup on the vette is located in the same place as the camaro? correct?
also that leaves me with where to get the bracket for the a/c compressor? any help in that area.
I have been to car-parts.com several times and there are an ass load of camaro's but very little vette's and the one thats in largo is not there any more ( I called). but if an oil pan swap is possible to solve the problem then I may just luck out.
thanks
Old Jan 19, 2005 | 02:04 PM
thanks
If I recall, the pick-up tubes are the same. Bolt patten is also the same for sure. The AC and accessorys are in diffrent locations on the vette from the LT1 in the firebird, but it would be very easy to swap them.
Old Jan 19, 2005 | 04:04 PM
kender's Avatar
gadget man
so then just a stock vette lt1 accesory bracket would bolt up and work on the lt1 camaro/firebird?
Old Jan 20, 2005 | 05:55 AM
myltwon's Avatar
Bolt-On 2v GT
same motor different brackets, intake, and oil pan
Old Jan 20, 2005 | 03:34 PM
kender's Avatar
gadget man
so then the holes to use the vette bracket should be on the camaro block, just empty or used for a different bracket with a different shape. and the intake isn't one of the parts that I have been told to worry about, but that is good to know. thanks
Old Jan 21, 2005 | 08:27 AM
myltwon's Avatar
Bolt-On 2v GT
not intake manifold just the air intake
