Need help Guys! LT1 nitrous
Old Jan 11, 2005 | 02:52 PM
GTman85's Avatar
KBizzzle
Default Need help Guys! LT1 nitrous
Tryin to install a NOS wet kit to my car. Ive got all the wiring done, everything. Only thing left to do is mount soleniods and the problem that im having......SPLICING INTO THE FUEL LINE. Im not to familiar as how to do it or where. A brass "T" fitting into the cut fuel line or what Anybody got any helpful info with this installation. Also i dont know if you can use the bleeder valve on the back of the fuel rail???
-kyle
^^Makes me warm and fuzzzzy
Old Jan 11, 2005 | 03:07 PM
myltwon's Avatar
Bolt-On 2v GT
pm formula69
Old Jan 11, 2005 | 03:21 PM
VERTFIVEO's Avatar
HATES STUPID PEOPLE
its in the rear of the intake , near the center, hard to reach kinda but once you find it its easy
Old Jan 11, 2005 | 03:47 PM
GTman85's Avatar
KBizzzle
rear of intake as in line that runs to the regulator?
Old Jan 11, 2005 | 04:22 PM
NXz28's Avatar
TR Balla Donor Supreme
Yes, you can use the shrader valve fitting on the back of the intake that's located on the fuel line that connects to the regulator. You will need a shrader valve removal tool to unscrew the inside from it, then just connect the fuel line to the noid. I think its a 4an size fitting...
Old Jan 11, 2005 | 04:25 PM
myltwon's Avatar
Bolt-On 2v GT
Old Jan 11, 2005 | 04:30 PM
GTman85's Avatar
KBizzzle
So if i can get the indside of the schrader valve out then i can just hook up the fuel line from the noid to the valve? If so ive already got the 4an fitting on it
Old Jan 11, 2005 | 05:19 PM
NXz28's Avatar
Yes, once you remove the inside of it just connect to fuel noid.
Old Jan 12, 2005 | 08:13 AM
GTman85's Avatar
KBizzzle
OK if i use the schrader valve how will you be able to check fuel pressure. Is there another way to check it?
Old Jan 12, 2005 | 10:07 AM
Half Fast's Avatar
LT1's are slow!
Maybe a fuel pressure gauge? Mount the sender off a T
