L98 Aluminum Corvette heads
Just looking for a ballpark dollar figure for how much these will go for at a junkyard. Also, what would I be paying for a good rebuild and port job?
-Joe
-Joe
depends where you go, miles on heads, amount of compenents on heads
could be anywhere from 50 - 300 bucks just depends who and where mainly
I wouldn't want old springs and valves if it's been sitting
valve stuck open + piston upstroke = $$$$$
I would imagine they would thoroughly clean and inspect both the valves and springs in the process of a head rebuild, leaving little chance they would still stick. I'll probably have them replaced anyway depending on what kind of port size is available and what kind of cam I get but I was mostly looking for pricing for now. If I can get a set for around $200, then thats not too shabby. What kind of availability do you guys think there will be on an item like this?
-Joe
-Joe
For availability check local junk yards, and ebay. As far as a rebuild goes, the heads will need to be: cleaned, dissambled, valves checked, valve job, resurfaced, assembled, springs checked and shimmed for correct spring spressure. You will have to buy aftermarket springs if you run an aftermarket cam with more duration/lift. Expect to pay about $250-350 for machine shop fees depending on what you get done and where you go. Springs are about $100-150 extra. Valves cost $10-15 each extra. I'd say 2.00 or 2.02 valve are the bigger valves you can fit on those without having to install larger seats. Installing larger valve guides is about $15-20 per valve. Installing larger valve seats for bigger valves is usually $15-20 per valve.
-Joe
-Joe
