Surge At Idle
I have a surge at idle, and I'll list everything I've
changed/cleaned/etc. If anyone has anything else I should check
PLEASE chime in or any words of wisdom.
-TPS
-IAC Valve
-Driver Side o2 Sensor
-Cleaned MAF Sensor
-Cleaned MAP Sensor
-Changed TB Gasket
-Cleaned IAT
-Cleaned IAC Passages
-New NGK TR-55 Plugs
-New Wires
-New Coil
-New EGR Valve
-New Passanger Side Exhaust Gas Check Valve
-Cleaned Driver Side Exhaust Gas Check Valve
-Cleaned Throttle Body
-TPS
-IAC Valve
-Cleaned MAF Sensor
-Cleaned MAP Sensor
-Changed TB Gasket
-Cleaned IAT
-New Wires
-New Coil
-New EGR Valve
Originally posted by Half Fast
Check for air leaks.
also know any good vacuum diagrams for a basic lt1?
