how big can you port an lt1 throttle body?
I'll sell you a stock, unported LT1 intake manifold and stock unported 48mm throttle body that will support 500+ HP ( at the crank because that's what they are talking about too) for the same amount that they are asking. Deal?
Originally posted by Half Fast
hardware refers to bolts, nuts, brackets etc. not LT1 heads
T.R. $100,000 kill club member #002
Turtle crew member #2
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
aaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
ouch this thread hurts.
did someone say there have a lt4 intake for lt1 heads and its not going t be a paper weight?
Originally posted by Sneakin Deacon
wouldnt you need larger TB plates aswell?
i was just gunna get a 58mm BBK monoblade..
and i dont believe an LT4 intake manifold is compatible with LT1 heads..but i could be wrong.
58mm isn't the mone blade. i'm not even sure what mm it would be called. but i know its big.
the 58....
mono...
those are plastic ones but samn thing....
a monoblade would simply be rated in CFM's...
So lets sum it up-
U cant use an LT4 intake with LT1 heads "It features raised intake runners for inporved flow and proper port alignment for LT4 cylinder heads. "
52mm is max bore on a 48mm housing
Bigger isnt always better ie velocity
Consider going to 52mm when u have 400+ flywheel hp.. or if u have 360ish and reving to 7000rpms instead of 5700rpms..
So lets sum it up-
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
"SLOW LT1"
Blue 2005 Acura TSX
lol, i know you know what he meant, but there is a point when to big is too much, and the same applies to the opposite. only thing i can equate it to, is having a tiny little paper ball, taking a deep breath, mouth wide open, and pushing it when you exhale...then do the same with your mouth shut some, and your lips making a slightly larger than whistling, hole. itll go much further this time. then you could try the same with your mouth shut, and barely parting your lips...like using a paperclip to part them slightly to let a minute amount of air out.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
