fuel problems small block chevy
Old Oct 22, 2004 | 05:11 PM
fastisfun's Avatar
Default fuel problems small block chevy
took my car to the track and around 3000 rpms they would drop an go back up then drop. i had to stay on the throttle an it eventually would go an i could shift. it has a stock fuel pump that i pressure tested it a it has 10 psi at idle. so i thiink it is lossing pressure when i am at full throttle. edlebrock carb on there now and rebuilding a holley with vacum secondaries. any suggestions thanks
Old Oct 22, 2004 | 05:15 PM
Drace1963's Avatar
Member
run your fuel pressure at about 7 psi. make sure your idle air holes on top of your carb. are clean. With the fuel pressure that high, you might be flooding it out. check float levels too.
Originally Posted by Zate
i still stand by the fact that 75% of 16-23 year olds are dropped babies.
Originally Posted by Boosted240
Mustangs are the hondas of the domestic cars. The drivers are always doing ricer revs and just like hondas, about the only place you cant buy parts for them is at 7-11.
Old Oct 23, 2004 | 09:19 AM
fastisfun's Avatar
how do i lower the pressure on a stock fuel pump
{FOR SALE} S2K https://www.tamparacing.com/forums/c...nda-s2000.html
Originally Posted by BAMF
I would buy an entire swimming pool full of Cocaine.
And I would swim in it.
Old Oct 23, 2004 | 09:31 AM
Drace1963's Avatar
Member
with a fuel pressure regulator
