Can some one break down the difference between an LS2 and a LS6
I am not very GM literate, so you will have to excuse me. What are the differences between an LS2 and LS6? The 25 hp is obvouis, but what makes them different motors? Thanks in advance.
LS6 is 346 ci
LS2 is 364 ci
LS6 has a 75 mm TB and LS6 intake
Ls2 has a 90 mm TB and an all new intake that should be VERY good
LS2 has a slight bump in compression over the LS6
LS2 has a few sensors located differently
Both use LS6 heads except I believe the LS2 does not use a soduim filled hollow exhaust valve..too expensive to put in a high volume production motor...the LS2 will be in trucks, GTO and several other vehicles.
I THINK the LS6 cam is probably a bit more aggressive...just slightly.
The LS6 HP graph does peak higher than the LS2 but the LS2 has more HP under the peak, or under the curve. I think the LS2 may actually be as fast or faster than the LS6 in the same car.
Other than that they share most of the same dimensions and parts should be relatively interchangable with LS1/LQ4/LS6/LS2
Having the 4" bore aluminum block is going to be a godsend. Add a 4" stroke crank and youll have a 402 ci aluminum motor with factory sleeves. Naturally aspirated 500+ rwhp 402 aluminum motors may be a common sight in the next few years.
LS2 is 364 ci
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
I agree. If Ford had a 364 ci block to use with thier 4 valve heads it would be a monster. They could raise the compression a bit....it wouldnt use that much more gas until you put your foot into it.
I dont know why they dont do it. Hell even Nissan has a 5.6 liter V8 now.
Some one need to come up with a way to get more bore from those blocks. They would be a hero.
