compression ??
Old Jul 2, 2004 | 01:12 PM
6-speeder's Avatar
Default compression ??
need some help lowering comp.are there any thicker head gaskets than .060?if so who makes them?right now i got a 355 with 12.39to1 im trying to get it to run on pump gas.buying different pistons is not an option,the motor is brand new and i got a deal on the pistons.how much can a 72cc head from 64cc drop the comp?
87 Grand National
Limit TA-62,3in.THDP,PTE intercooler,65 inj.,9x11 billet converter,marshall chip
Old Jul 2, 2004 | 03:28 PM
Shockwave's Avatar
Come get Some
You dont want to go with thicker gaskets, it is going to increase your quench distance considerably.. although if you really must, you can get a shim gasket to stack on top.
Only The Strong Survive.
Raise your kids not to be unruly punk ass fucktards and you won't ever have that problem I didn't see him attack any other kids on the bus.
Old Jul 2, 2004 | 04:22 PM
Country Boy's Avatar
can survive...
Default Re: compression ??
I dont think you can get a thicker head gasket aznd adding a shim is just asking for leaks. The only way without changing the pistons is getting a larger chamber head. The ones you said shold be half a point or maybe even a point drop.
Old Jul 5, 2004 | 07:16 PM
Sneakin Deacon's Avatar
PSSHHH x2
http://www.turbofast.com.au/TFcomp.html
355 = 4.030 bore / 3.48 stroke
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
