Finally made it to the track
Old Jun 25, 2004 | 08:55 AM
obrien2's Avatar
Default Finally made it to the track
Well last night I finally made it to bradenton. I wasn't too happy with my times. My best run was 12.98 @ 109.74 on a 2.0 60'
I think with some better traction and better weather, I should get the times down a bit though.
Old Jun 25, 2004 | 09:20 AM
Young,Fablous,&Broke's Avatar
Not to bad for your first time out in the car.
Old Jun 25, 2004 | 11:23 AM
24-7's Avatar
Civic Racing eXperiment
+1...practice makes perfect
Old Jun 25, 2004 | 12:16 PM
HybridSS's Avatar
I have fuzzy eyebrows
6 speed tranny and gearing is tough to get right. Launching a 6 speed is even harder. You have a great trap speed...enough for mid 12s easy. Get that 60 foot down to a 1.80 and you will be mid 12 no problem.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Jun 25, 2004 | 04:39 PM
Sneakin Deacon's Avatar
PSSHHH x2
slap some nice DR's back there if your still running the things maher put on
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Jun 26, 2004 | 06:14 PM
obrien2's Avatar
once the tranny is fixed, I will be getting some nittos, and then a cam. How hard should I be able to launch the car with the nittos. I quess I should address the axle hop problem that I have as well. Any recomendations on that?
for the most part the car was very consistant. 5 of my runs ranged from 12.98 to 13.072. Those runs all had 2.0 60'. My other 3 runs were in the 2.2 range and I had one missed shift. The hardest I launched on any of my passes was a 2000 rpms. I just need to get some DRs and try again I quess.
Old Jun 27, 2004 | 10:00 AM
PSSHHH x2
i would think it does, but are there aftermarket LCA's and subframe connectors on the car? and are you dumping the clutch, or feathering it out.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Jun 27, 2004 | 11:09 AM
obrien2's Avatar
Yes the car has LCAs and subframes. I wasn't really dumping the clutch, atleast I don't think I was dumping it that hard, mabey thats my problem, just getting a bit too excited.
Old Jun 27, 2004 | 03:09 PM
97blkz's Avatar
not bad! you dynoed 330 something right? Sticky tires should help out and maybe find 2-3 10th's!
Old Jun 27, 2004 | 04:11 PM
HybridSS's Avatar
rear sway bar and BMR relocation brackets if you dont already have them.
