97 Trans Am help pleez
Old Mar 29, 2004 | 02:31 PM
mustangman98's Avatar
Mullet Powered
Default 97 Trans Am help pleez
i have a friend who has a 97 Trans Am and she is having lots of trouble with it. first off the compressor for the AC is making a hell of alot of noise but its only the pulley making the noise, when you spray belt dressing on it it shuts up till it fries and then starts squeaking again but it still blows air throught the vents when you turn on the AC. so she might need a compressor or something. also another problem she is having is that the ground wire on her brake lights is screwed so when you shut the door hard the brake lights will come on at any random time of the day or night., she has to push the brake pedal and they go off so i have really no idea how to fix that.
so what i really need is a place that has used parts for trans am, unno like speed shops that will have like 50 of them laying on the floor of there garage. any help would be greatly appreciated.
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Mar 29, 2004 | 04:02 PM
WHY_NOT???'s Avatar
umm wire it right its easy, and as for the compressor sure its pulley or the compressor? cuz pulley could need some oil or new belt or it could be a new compressor or the compressor coild need oile there is quite a few different things that that could be
2013 Ford Escape Titanium - grocery getting power
TR's Tactical Trunk Monkey Crew #001
Midgets and Beer!!!
the book of faces
Old Mar 29, 2004 | 05:25 PM
Mullet Powered
well it has a brand new belt and the pulley is turning but when you spray dressing on that pully it shuts up and then dries up and statrs squealing again. so for sure its something to do with the pulley or shaft, bearring, etc. as for pumping air it does that fine, its just something with the pulley making noise.
03 Gt - SOLD!
Old Mar 29, 2004 | 05:39 PM
ZDriver96's Avatar
change the belt again.. doesnt make sense if the bearing or somethings messed up that when u spray it, it goes away..
Get a wire diagram of the brake system... and check it with a multi meter or just rewire it with new wire running it along the old path.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Mar 29, 2004 | 08:39 PM
Mullet Powered
its not the belt, the pulley on the compressor is stiff for some reason and not spinning easily.
03 Gt - SOLD!
Old Mar 30, 2004 | 09:47 AM
Topless T/A's Avatar
Voice of Reason
http://www.tacreationsusa.com
real nice guys, and have more parts than any of us could ever want...I mean they have it all...decently priced and they ship it out either same day or next day...located in Florida so it gets to you quick too
Assemblage 23
Negative Format
I'll work to elevate you, just enough to bring you down.
