Found my new engine
Old Mar 28, 2004 | 08:57 AM
ZDriver96's Avatar
Default Found my new engine
Im found a smoking deal on a LT1 short block.
SRP pistons 11.7 compression
Scat 9000 crank
Eagle forged H beams ARP rod bolts
ARP 2 bolt mains
clevitt 77 bearings
800 miles on it. From a respected member on camaroz28.com which makes me feel comfortable about buying it.
He told me it has some special over fed gerbels in it that'll make the car get up and go.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Mar 28, 2004 | 09:31 AM
SPLATT's Avatar
TONIGHT....YOU....
sounds pretty sweet man, good luck
"My CaR Are SlOW"
1985 monte carlo SS *under construction*
2002 T/A Firehawk #0490. M6. A few RWHP/ more RWTQ.
Old Mar 28, 2004 | 12:10 PM
Country Boy's Avatar
can survive...
Careful with the compression. Almost too high with our air down here (HOT) and definately no less than 93.
Old Mar 28, 2004 | 03:03 PM
ZDriver96's Avatar
My XE bleeds off alot of exhaust. 230/236 duration. Pull back the timing some if i have too...
I think that'd be ok. What do u think?
"SLOW LT1"
Blue 2005 Acura TSX
Old Mar 28, 2004 | 03:21 PM
TheShow50h's Avatar
The little 5.0 that could
Stock compression is 10.5:1 if I'm not mistaken ... so if you were to just back off the timing a little like you said with that cam I'm sure you'd be fine.
Maybe even use a thicker headgasket.
-Vince
Old Mar 28, 2004 | 03:41 PM
ZDriver96's Avatar
Yeah i have to find out if that compression is with a .29 , .39 or .49 thick gasket..
The quench on the LT1 isnt optimal... so a .29 brings is closer to ideal... Which i what i run but i might not if 11.7 was off a .49 gasket
"SLOW LT1"
Blue 2005 Acura TSX
Old Mar 28, 2004 | 04:40 PM
97blkz's Avatar
Leon this is good news to hear! Maybe we can get the install done at rev x? I'll help , well try!
Old Mar 28, 2004 | 04:56 PM
ZDriver96's Avatar
Aight... i'll find out what were doing..
"SLOW LT1"
Blue 2005 Acura TSX
