I dont think the 2nd set of barrels are opening at full throtel?
Old Mar 22, 2004 | 07:30 AM
JimmyHat's Avatar
Sphincter Say's What?
Angry I dont think the 2nd set of barrels are opening at full throtel?
I dont think the 2nd set of barrels are opening at full throtel? or there is no gas being dumped in the rear barrels? for a 350 it runs like a 305? specs would include 350 010 block casting bored .30 over with new minimal dish pistons, new cam with a 447 lift, heads were from the vortec 305 that I had completely re-done with a 2 angle valve job. Edelbrock performer vortec intake, Edelbrock 1406 650cfm electric choke, Malory 50K volt coil with billit distributor. New everything!
Old Mar 22, 2004 | 08:31 AM
Young,Fablous,&Broke's Avatar
i didnt know you could use the 305 heads on a 350.
Old Mar 22, 2004 | 08:37 AM
HerHotRod's Avatar
The Happy Mrs.
Check your throttle cable, it may need adjustment w/ your new carb. Make sure when the pedal is on the floor you get full throttle at the carb.
Old Mar 22, 2004 | 09:43 AM
JimmyHat's Avatar
Unless you get a bigger cam with a larger duration... do you think it could be something with the vacume lines in the car? not sucking the gas through the back barrels?
Old Mar 22, 2004 | 04:58 PM
Country Boy's Avatar
can survive...
Originally posted by Mars_302
Yea you stick 305 heads on a 350 for more compression, but you usally end up some dinky size valves
That and the intake runners are smaller so your starving the motor for air.
Old Mar 22, 2004 | 06:20 PM
I thinc the 305 heads are the problem...
Old Mar 22, 2004 | 07:18 PM
BlackZ28's Avatar
ppssshsshhhhhhh
Default Re: I dont think the 2nd set of barrels are opening at full throtel?
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Old Mar 23, 2004 | 03:39 AM
JimmyHat's Avatar
ok forget about the heads, thats not the problem here. think other solutions..
Old Mar 23, 2004 | 04:30 AM
can survive...
Thats half your problem.......
Are the secondaries vacum controled or linkage? Check the float level in the rear bowls?
