'67 327ci Mystery Problem...
Old Mar 11, 2004 | 06:23 PM
Wilson6t7's Avatar
Default '67 327ci Mystery Problem...
I recently installed a new RPM performer manifold and 670 Holley Street Avenger carb. #s 6, 7 & 8 cylinders are running very hot as evidenced by discoloration of my ceramic coated headers. These pipes have actually looked red in the top 3 - 4 inches where they bolt to the head. Timing is 10 degrees advanced with no vacuum advance. I cant see the carb being lean or more than 3 cylinders would be affected I would think. The timing cover and damper were reinstalled in original position. I have not changed anything else. Water temp is 195 with gauge probe in intake manifold. Any ideas at all whats happening? I never had any problems before this upgrade.
Old Mar 12, 2004 | 05:22 AM
Half Fast's Avatar
LT1's are slow!
Check to make sure the rockers on those cylinders are not too tight.
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Old Mar 12, 2004 | 06:29 AM
Young,Fablous,&Broke's Avatar
Thats the same motor i have.. Howver I can't do anything other than to wish ya luck!
