El camino engine swap
Old Nov 23, 2003 | 04:33 PM
kender's Avatar
gadget man
is the optispark the type of distributor that can have a coil upgrade by removing the internal coil and running the coil wires to an external msd coil like the blaster ss. what is the main issue that causes the optispark to have the reputation of being a pain? and why not just replace with an msd distro then? or am i just repeating what others have asked before?
I checked the lt-1 and from what I found it looks the have 265 - 330hp depending on whether it came from a caprice or a camaro and what year, it also gets 17-24mpg city/hwy (at least thats what the factory says).
for turbo later on what boost can the stock internals take? 10-12psi like other engines with a 10:1 compression or is it less? eventually I will rebuild the engine with a strong bottom end and lower compression to accomodate the higher boost that I may run. any suggestions?
U.S.S.A Crew Member #001
