Would this work?
Old Jun 20, 2003 | 11:35 AM
RavinGAzN's Avatar
Default Would this work?
http://cgi.ebay.com/ws/eBayISAPI.dll...category=18796
Running a 12 inch Alpine Type R.
Sub Specs:
Diaphragm Material : Kevlar Reinforced Pulp
Magnetic Weight : 89.4oz.
Mounting Depth (top mount) : 178mm (7”)
Mounting Diameter (top mount) : 275mm (10-7/8”)
Recommended Box Types : Sealed/Vented/Bandpass
Recommended Sealed Box Volume : 0.7 – 1.0 cu. ft.
Spider Material : Nomex
Voice Coil Diameter : 50mm
Power Handling
Power Handling Capacity (Peak) : 1000W
Power Handling Capacity (RMS) : 300W
Thiel Small Parameters
Coil Height (Hvc) : 37.74mm
Cone Area (Sd) : 467.59 sq. cm
D.C.Coil Resistance (Re) : 3.6 ohm + 3.6 ohm
Electrical Q (Qes) : 0.45
Equivalent Suspension Stiffness (Vas) : 58 liters(2.04cu.ft.)
Free Air Resonance (Fs) : 28Hz
Frequency Response : 24Hz - 1kHz
Gap Height (Hag) : 10mm
Impedance (Nominal) : 4 ohm + 4 ohm
Inductance (Le) : 3.85mH at 1kHz (1.34mH at 20kHz)
Linear Excursion (X linear) : 13.87mm
Maximum Excursion (X peak) : 27.7mm
Mechanical Excursion (Peak-to-Peak) : 55mm
Mechanical Q (Qms) : 8.31
Sensitivity : 87 dB/W/M
Total Loudspeaker Q (Qts) : 0.43
Old Jun 20, 2003 | 11:52 AM
Tom's Avatar
Tom
Strict Machine
it would be fine, but i question the quality of that amp
2012 FIAT 500 ABARTH
Old Jun 20, 2003 | 01:23 PM
RavinGAzN's Avatar
yeah, i know what you mean. But my friend ran 2 12 polk momo's off it, and said theyre great. I wanted something like mtx or JL, but i just dont have the money for them. Thanks.
Old Jun 20, 2003 | 01:39 PM
93ex's Avatar
Just Ledoux it!
as a rule of thumb, dollar per watt
and I personally woulnt run that amp @ 2 ohm load bridged
i take it you changed your mind on the sub too
IM lookin for a decent 200 watt amp to power a alpine 10 inch type R. My budget for the amp is 200 max, but it better be reaaally fuckin worth it. This is not a big system obviously, but i want an amp that wont suddenly break apart.
Thanks/.
Old Jun 20, 2003 | 01:52 PM
RavinGAzN's Avatar
yeah, went with a 12 type r. And what do you mean 2 ohm bridged?
Old Jun 20, 2003 | 02:42 PM
93ex's Avatar
Just Ledoux it!
well the type r specs yu gave said dual 4 ohm voice coil. 2 ohms or 8 ohms. paralell or series.. 2 ohms give you more power (so to say) but the amp will work arder, and I question the ability of that amp @ 2 ohms for too long
Old Jun 20, 2003 | 05:08 PM
RavinGAzN's Avatar
ahh, i think i know what your saying now, well thanks for the hint, i guess ill be doin some more research.
Thanks.
