10 tips for safe, sure-footed brakes
Old Apr 15, 2026 | 06:06 AM
Default 10 tips for safe, sure-footed brakes
Clean every thing really well before starting or buy all new.
By Carl Heideman
Apr 14, 2026
1. Pick the Right Compound
  • Racing compounds go on a race car, while street compounds go on a street car.
  • Hawk Autocross pads work really well on the street.
2. Look for Leaks
  • If anything is leaking in your braking system, fix it immediately. Make a visual inspection of all brake components and look for wet areas–you should find none.
3. Make Sure They’re Assembled Correctly
  • If a car has had at least one previous owner, assume that someone with a lack of mechanical ability has touched the brakes.
  • Look it up on the internet.
4. Bleed Them Correctly
  • We’ve always preferred the two-person way: One person goes to each wheel and bleeds the brake according to the shop manual instructions, while another person works the pedal.
5. Adjust the Drums
  • After making sure the adjusters are not frozen, adjust the brakes so they just start to drag.
6. Adjust the Parking Brake
  • Stuck parking brakes can quickly make brakes feel and act funny, plus wear out things out quickly.
  • Lube those cables really well.
7. Check the Hoses
  • A visual inspection of flexible brake hoses is pretty easy–look for leaks and cracks, discarding any hose with either.
  • Or buy new clean rubber.
8. Check the Linkages
  • After you’ve checked that all the components are not leaking and are in good shape, look for wear (and therefore compliance)
  • in the pedal/master cylinder linkage and in the rear brake/parking brake linkages.
9. Rotor & Drum Surfaces Matter
  • Obviously, grooves are bad, but so is glazing.
10. Do You Really Need Those Big Brakes?
  • If you can lock up your wheels and tires, you don’t need bigger brakes–you need stickier tires
Chassis & Suspension Tech
Oct 11, 2021 09:08 PM
Jan 7, 2020 04:56 PM
Boso Drifter
Nissan/Infiniti Tech
6
Mar 24, 2006 10:04 AM
Ian MMF
Aug 27, 2005 06:26 PM
Evangelion
6
May 21, 2003 04:38 AM
