What Gear Ratio Should You Put In Your Car? Gear Ratios, Explained
Old Sep 24, 2025 | 04:23 AM
Default What Gear Ratio Should You Put In Your Car? Gear Ratios, Explained
GearFX Driveline
1.21K subscribers
121,548 views Feb 10, 2023
It’s one of the most common questions when it comes to a project car build: what gear ratio should I run? It’s a loaded question because there are a lot of factors that go into deciding what your final drive ratio should be, including your engine’s camshaft and your transmission choice. Let Lucas from GearFX explain what you need to consider when you are trying to select a gear ratio for your vehicle.
Old Sep 24, 2025 | 04:31 AM
Default Ring and Pinion Gear Ratios Explained: How to Choose the Right Gear Ratio
Rear Wheel Performance
4.03K subscribers
17,067 views Apr 20, 2022
This Theory from a Mechanic episode Tom and Erick discuss how to determine if a vehicle is under-geared, gear calculators, and go in depth through the changes and results to our vehicles: Ford F150, Mustang GT, and the Dodge Challenger. See why increasing the rear end's torque does NOT necessarily mean sacrificing fuel efficiency with real world testing.
LuckyH
May 15, 2007 04:25 PM
trev0006
Sep 30, 2006 07:44 PM
trev0006
Aug 28, 2006 12:47 AM
trev0006
Jun 20, 2006 04:22 PM
trev0006
May 9, 2006 09:07 PM
