Antigravity batteries....this good? compared to regular batteries?
Old Nov 5, 2021 | 09:28 AM
Default Antigravity batteries....this good? compared to regular batteries?
https://antigravitybatteries.com/lit...SAAEgIB0vD_BwE
Search for:
0 / $0.00
Benefits of Lithium Batteries
Home » Benefits of Lithium Batteries
The BEST Battery EVER?!
That’s a bold statement… but we feel it holds true if you are looking for the best Starter Battery for your Car, Truck, Motorcycle or Powersport vehicle. Antigravity Lithium Batteries offer features that will save you from being stranded, last years longer than lead/acid, and also increase the performance of your vehicle. For example you would save 70% in weight over lead/acid batteries, while having built-in Jump Starting so you will never be stranded, then top it off with a much longer Lifespan than lead/acid batteries and you will see why we believe ours is the best Starter Battery ever!
Benefits of Antigravity LITHIUM Batteries
  • LIGHTER WEIGHT
Lithium-Ion batteries are up to 70% lighter than equivalent lead/acid versions. This helps make your vehicle lighter and more efficient. Enjoy better starting and handling, shorter braking distances, better acceleration, better gas mileage, and many other performance benefits. On average in an Automotive application the weight savings are from 25 to 40 lbs just swapping the battery out! This is the most cost-effective weight-loss product for your vehicle by far!
Antigravity Small Case Lithium Batteries for Motorcycles and Powersport Vehicles only weigh from 13 oz to 3 lbs yet they offer the most power & performance in the most compact size of any lightweight LiFePO4 motorsports battery on the market! Our new Car Batteries are just 9 to 15 lbs meaning you can save up to 40 pounds just swapping out your lead/acid battery for our Lithium Battery. Take note Racing/Performance Drivers and Riders!
  • HIGHER POWER
Antigravity Lithium Batteries have up to 3 Times the Cranking Amps of similar sized lead/acid batteries. Our battery will turn over your Hi-Performance motor with ease! Offering fatter ignition spark and higher voltage at start-up for a quicker turn-over of the motor! They work much better for Hi-Performance/Racing Motors by providing a much higher cranking pulse than lead/acid.
  • LONGER CYCLE LIFE
Antigravity Lithium Batteries offer over Twice the Lifecycle of Lead/Acid, and even other lithium batteries due to our full Battery Management System (BMS)*. Our built-in BMS Circuitry keeps the battery in the optimal operating range for the longest life. Additionally the BMS protects the battery from Overcharge, Overdischarge, and has Thermal and Short-Circuit protections for the safest operation possible. (*RE-START models have Full BMS; SMALL CASE Models do not have these protections.)
  • DURABILITY
Lithium batteries are much more resistant to vibration than lead/acid. Their incredible shock- and vibration-resistance makes them perfect for Racing and other applications requiring a durable battery. They are also less prone to heat damage than lead/acid.
  • VERSATILE MOUNTING and SAFER INSTALLATION
You can mount our battery in any orientation in the vehicle without fear. There is no acid to spill out or anything that can damage your paint or battery tray. Take note all you classic car builders.
  • ENVIRONMENTALLY SAFER
One of the best reasons to switch to Lithium-Ion batteries is that they are much cleaner and safer for the environment than lead/acid. No Acid or Heavy Metals such as Lead, Cadmium, or Mercury. Won’t release dangerous Hydrogen while charging. Won’t leak liquids that are damaging to your finish or chassis such as acid.
  • OVERALL COST SAVINGS and VALUE
Lithium batteries cost more upfront than lead/acid batteries, but they offer a lower cost of ownership over the lifespan of the battery. For example they offer over twice the lifespan of lead/acid, and several benefits such as the light weight, and most importantly the RE-START built-in Jump-Starting. It will save you from being stranded and will pay for itself with just a few uses, saving your time and energy and avoiding a dead-battery emergency.
Added Benefits of Antigravity RE-START
  • JUMP-STARTING BUILT-IN
Left your lights or stereo on and drained the battery dead? No worries – the new Antigravity RE-START Battery is the World’s First with Built-in Jump-Starting! The battery will intelligently monitor its status and if it senses over-discharge will put itself into a sleep mode, saving enough energy to allow you to restart your vehicle. Simply press the button on top of the battery, or use the included Wireless Keyfob*, start your vehicle and drive away. No Jump-Starter or assistance needed! (*Our Car Batteries have WIRELESS Jump-Starting built-in. No need to even access or touch the battery.) Learn more about our RE-START Technology.
  • FULL BATTERY MANAGEMENT SYSTEM
Our new RE-START Batteries for Powersports and Automobiles are equipped with a sophisticated Intelligent Battery Management System (BMS). The BMS offers protections against over-discharge, over-charge, and short-circuiting as well as thermal protections and cell balancing. The BMS acts as a gate-keeper so that the battery cannot be subjected to operation outside its optimal range. This makes for the Safest, Longest-Lasting Battery possible and allows you to get the most life-cycle from the battery.
  • LOW SELF-DISCHARGE
Antigravity RE-START Batteries do not self-discharge like lead/acid batteries. They offer a longer storage time and can hold a charge up to a year provided there are no “Parasitic Drains” (accessories that draw power when vehicle is off, i.e. alarms, ECUs, GPS, heated grips, and other accessories the vehicle might have).
Automotive
View products
Motorcycles/ Powersports
View products
Small Case
View products Check out the SUPER SALES for awesome discounts!
(Not for Resellers)
Shop
Support
Info
Partners
Contact Us
310 527 2330
me
May 18, 2006 08:58 PM
ttgoth
May 17, 2006 02:27 PM
99TL
Jan 21, 2004 07:56 PM
