Close to stripped nut
Old Mar 4, 2003 | 07:13 PM
Bob22b's Avatar
Default Close to stripped nut
I'm trying to take my midpipe out so I can fix a rattly heatshield. One nut is rusted and I tried it after some liquid wrench and I could feel it was about to slip. Then it did. It still grabs some.
What should I do about this stubborn nut?
Old Mar 4, 2003 | 07:52 PM
Tony's Avatar
Senior Citizen
I have yet to find a nut or bolt I could not remove with vice grips.
10' 1198S
09' Ninja 500R
09' Stella
Old Mar 4, 2003 | 07:57 PM
Bob22b's Avatar
I was about to do that, but my father advised me against it. He told me that it will strip it further, maybe you're just the master of the stripped nuts.
Old Mar 4, 2003 | 08:02 PM
Tony's Avatar
Senior Citizen
you get it to where it requires the hand of god to tighten the clamp of the vice grip on, and yes, will prolly render the nut not useable, nuts are cheap, you said you wanted to remove it, not keep it for all time
10' 1198S
09' Ninja 500R
09' Stella
Old Mar 5, 2003 | 12:38 PM
Bob22b's Avatar
haha, true
I tried the vice grips. THe bitch bolt is still not budging (It's really the nut, but bitch bolt sounds good).
Argh, I hope the other 3 will be a lot easier. Hope I don't need to bust out my rock climbing strength and take the thing off with my hands.
Old Mar 5, 2003 | 12:51 PM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
i had the same issue. dropped the entire exhaust system. them i went and got a torch. heated it up then i sawed the bolts off. thats what i did. im really good at finding a way to get things off. even it means breaking it.
tamparacing.com
Old Mar 5, 2003 | 02:28 PM
0HP930's Avatar
Guest
Use either a cutting torch or a cutting disk on a dremmel or rotary tool.
Old Mar 5, 2003 | 02:43 PM
richsrotary.com's Avatar
12 point new socket.
Got Wankel
Old Mar 5, 2003 | 03:40 PM
BlackLT1's Avatar
Team Speed Member #01
Use Billy Mays adjusting bolt wrench
The very existence of the flamethrower proves that somewhere, someone said to themselves, "I want to set those people over there on fire, but i'm just not close enough to get the job done."
Old Mar 5, 2003 | 05:23 PM
Bob22b's Avatar
I think it's seized from all the heat. Could I drive the car hard for awhile to get it heated up again then try to get it off?
The vice grips held, and I attempted to use the same strength found in the arms of god to break it loose. Nope.
I didn't want to break anything, b/c it is not budging.
