Gas and vapor engines outrageous mileage, killed and never publicized
Gas and vapor engines outrageous mileage, killed and never publicized.
Look at 5:00 minutes and see some printed proof.
https://www.youtube.com/watch?v=nqKE...UUjOss&index=5
Gas vapor carburetor
Gas vapor test with lawnmower. Just wanted to see if it worked.... and it did. Was fun making it but not sure if it is really more efficient than the normal gas intake.
https://www.youtube.com/watch?v=iP5Q_tenG2I
my vapor carb is finally working , it is simple but it does the job !
https://www.youtube.com/watch?v=tZjeBDLqJW0
Factory made
[h=1]Factory made gasoline vapor carburetor from the past[/h]https://www.youtube.com/watch?v=FDHQa0zv4D4
[h=1]Vapor Gas Injection Engine Documentary - 2016[/h]https://www.youtube.com/watch?v=Vrm9JzsnGU4
Tom in Toledo
In 1935 a man named Pogue patented a carburetor and had Ford motor company test it on a car with V8 motor and got 205.5 MPG. Look it up, I have the patents and how it works. Patent Number is 2,026,798 Jan. 7, 1936
Tom in Toledo
33MPG to 75 mpg and pictures of hardware
https://www.youtube.com/watch?v=U8hPPYzfn7Y
Join the forum!! The WTF Mod For more information
Fuel and Water Vapour System using less than $50 of off the shelf parts that doubled my gas mileage @ 55mph for only 3 hours work! Well... actually Hundreds of $$ and Countless hours of research have gone into this working concept. I hope it is appreciated
For more detailed info email MacGyver@Rescueteam.com
Testing prototype of gas vapor bubbler. I am no longer utilizing this method. You only use the most volatile fumes, some chemicals in gas have a higher boiling point than water! We must flash vaporize with heat to crack apart the long hydrocarbon chain into simpler elements and gases to achieve true complete combustion and end emissions.
https://www.youtube.com/watch?v=420kq_UFgtg
For vaporization of gasoline
Okay. After a couple months of experimenting, I've come to some conclusions.
Exhaust gas is perfect to force vapors into the engine. It's hot and rpm is proportionate to pressure which matches intake just like a turbo.
Tube / pipe heaters are the most efficient use of electricity to vaporize gasoline.
https://www.youtube.com/watch?v=luVkkH-Ylhs
https://www.youtube.com/watch?v=h3HJyRYoiSs
by Craig Carpenter
update and explanation
https://www.youtube.com/watch?v=Q5TGDNVSdQM
[h=1]Simple Fuel Vaporizer, Drip refil system.
https://www.youtube.com/watch?v=RNUfryhT4H8[/h]
by Craig Carpenter
