spark and fuel good. Wont fire up
Forever Broke Nissan
on
spark and fuel good. fired up! Now have valve tap...
just put in cam shafts into ls integ motor. it wont start up. if you turn the distributor all of the way to the firwall it will almost want to start. like a little flutter about every 4 seconds. need help tonight.
got timing belt on good. everything is trqed down to spec.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
on
yes we checked and double check. and now the battery died from trying to start it too much
Originally posted by Vapor
i think the cam timing is off
hmmmmm.... Timing. You need to not only make sure that the cams gears are spaced correctly, but that you are also @ TDC.
With the Crank @ TDC, make sure both cams gears are set correctly. The cam gears have the 2 "dots" @ the 90 and 180 degree mark, these must be level with the Head.
Sounds like you are 2-3 teeth off. (on either one or both cams)
Charles
Charles
My Blog: www.HotRodCaddy.com
on
timing is ok. we made sure about that last night. the camshafts are labeled IN and EX. so we didnt go wrong there. could it be too much over lap and loss of compression or what.
no i dont have a timing light. could someone come over and help get it started tonight
