Car runs off water....what happened to this guy?
Stan Myers
https://www.youtube.com/watch?v=WEp6ckvRtj0
https://www.youtube.com/watch?v=OXctY1K4wko
New open source water fueled engine
www.iusewaterasfuel.com
Read some of the comments posted with the videos here and above
https://www.youtube.com/watch?v=I4BkmDUN-cc
dcbourbonireland
assuming your talking about USA gallon that 3.83 liters that suggest ~200 watts makes ~1.2 liters a minute . Most HHO project seem to be about 200 watts to make 1 liter of HHO and the 100% mark seems to be ~135 watts for 1 liter .So your looking like your getting better results than most .However my thoughts are the more I look into this HHO business the more I figure that Stanley Myer had the right solution .In the HHO we see many gizmo that produce some liters per minute with the average theme that they use some ~200 watts of power to give back some 1 liter off HHO and then the HHO is injected in with carburetor or injectors . most all measures are liter per minute for these HHO devices .Stanley myer went the other direction. I think he figured out how much HHO do you need for every single explosion in the cylinder to replace the few grams of gasoline in the cylinder . As the gasoline enters in droplets much of it is wasted as the fuel hits the walls of engine or the cylinder and the fuel burns slowly.This means most gasoline is ejected out the tail pipe while still burning outside the engine. The HHO is a fast burn fuel so you can probably replace the gasoline with much less HHO gas compared to the wasteful gasoline . Gasoline fuel burns are reputedly in the low 20% and under with 17% seeming to be the most quoted ball park industry number . As HHO is a fast burn and we can expect close to 100% burn rate so possibly we need less than ~1/5th the energy to match the gasoline fuel . formulas suggest we need 2200 liter of HHO to replace 1 lier gasoline in energy equivalent .Using 1/5th of this suggests ~440liters of HHO could replace the same 1 liter of fuel in gasoline IC engine If you want You can work it out how much fuel in grams or parts of liter you need for each explosion event in the average 2800 6 pot IC engine at 3000 rpm typical for automatic big car IC gasoline engine doing steady 60MPH on the highway getting ~ 20MPG . Then you figure out the HHO equivalent in energy and replace it .My results best I can figure is each individual explosion event in IC cylinder supplies about ~1 watt of power .The secret I think Stanley Myer had was he saw that making the HHO outside the engine was too much hard work .So instead to make all the HHO outside the engine he chose to make the most of the needed HHO gas in hundredths of second for each explosion event to supply 1 watt of power inside the cylinder head and maybe get some extra HHO outside the engine..The side effect from this is that when the HHO recombines it forms water and the heat makes steam. That extra steam helps the explosion event push down the piston .He then i think saw that if he included extra water which was not made into HHO but carried into the combustion chamber as mist this might create extra steam and extra power . So i suspect Stanley Myer did not do any extra electronic gimmick to make HHO at less than the ~200watts of power we often use to make HHO . I suspect its more Stanley Myer made it where it would return more energy back than we put in with cheating and using the steam side effect to do that .My 2cents on the subject we should instead try to make the majority or all the HHO inside the cylinder instead from outside the engine. Your logic with your device suggest miniaturize it to fit inside the engine to get better results with IC engines and dont bother to patent it .first make it sell to your friend mother brother keep copies the sale document dates etc From that then put it out on the net worldwide you will always have the right to ,make it even though the others out there will produce it the right to make it will be enough to make money and once the cat is out the bag no point to put you six feet under like Stanley Myers .Good luck
https://www.youtube.com/watch?v=eXxN_nh84Pg
CLICK HERE for more info http://makefreegas.com/
TURN YOUR CAR/TRUCK INTO A HYDROGEN HYBRID
08-22-2014 12:14 PM
erikryan1017
For Sale/WTB Nissan
09-17-2013 08:27 AM
