supercharged Viper
Guest
Posts: n/a
I think it's hilarious that you even took my first post seriously, hell, you even seemed offended by it. I really think I can beat a supercharged Viper from a roll all motor.
I could'nt beat a 92 factory stock, convertible Viper from a roll on the motor. Try looking up sarcasm in the dictionary. Anyways, I've always been a fan of the pace car, I to once had a supercharged LT1 that saw alot of time at Skipp's. So I guess I'll see you on the bridge then.
Originally posted by "Bone"
easy way to up the fuel as you up the boost, like most haltech units run
Originally Posted by 400HP930
Then why bother with a seperate fuel source?
Its an easy way for going from 92 octane to 98 octane when you get on the gas.
I'm pretty sure they can fit 900 HP of fuel through the existing line from the fuel tank if they wanted to run regular gas through those injectors.
If I read the post above correctly he said there is an additional fuel tank for the supplimental injectors. I have read several articles about using special fuels for the supplemental circuit. Thats the reason why I assume he is not running the same fuel through the factory fuel injection and the supplemental injectors.
Ok he did have a spare gas tank in the back, i seen the injectors on the piping. Plus he went back to check the gas tank to see if there was fuel in it. He didnt say if it was normal 93 but my guess is yes.
Uncle Ben knows this SC'd Viper. It's too bad the guy paid all that money for Doug Levin to build it and then is afraid to drive it hard. He has wanted someone else to drive it at the track for him cause he's skurrred.
Uncle Ben
Slow domestic N/A automatic RWD w/LOTEC
Uncle Ben
