cadillac questions???
Old Jan 6, 2003 | 10:09 AM
chet's Avatar
All Aboard
Default cadillac questions???
how does this work...anyone have any ideas?
Cien features the new Northstar XV12, a 7.5-liter dual-overhead cam (DOHC) engine that generates an amazing 750 horsepower and 450 ft-lbs of torque. Advanced features include GM's Displacement on Demand technology, which allows the engine to run seamlessly on six cylinders at times to maximize fuel savings, plus a direct injection gasoline combustion system for increased engine power, and a combined starter generator.
Old Jan 6, 2003 | 10:40 AM
mpbiv's Avatar
Rod Bearing Eater
It kills spark and fuel to specific cylinders when not needed (might even have a system to keep the valves open so there is no compression, but I cannot remember). SAE International put an article about it in Automotive Engineering a while back which detailed exactly how it worked. I'll see if I have it laying around but its an older issue so I might have left it at home.
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Jan 6, 2003 | 04:45 PM
0HP930's Avatar
Guest
Oh man, its 4-6-8 all over again.
For those of you unfamiliar with this some caddies back in the 80s had a system that closed off the valves on certain certain cylinders depending on load which allowed a V8 to operate on either 4, 6 or 8 cylinders.
Old Jan 6, 2003 | 05:18 PM
BIG_Truck_Driver's Avatar
Wherever I may roam...
Boy was that a flop back in the day.
one would hope they worked out many of the bugs of the old system before they try to do it again.
Old Jan 7, 2003 | 02:19 AM
Rotary7's Avatar
Get Down-Or-Stay Down
The 4-6-8 was the worse fuckin Idea GM had in mind,Well compared to the 4.1L engine for the Caddy,Im glad mine is a 5.0 but its a Olds 307
Do you want to be tazed?
