Stupid LSD question.
LSD allows for both wheels to spin.. correct..
Is there any way a NON LSD rear end will burn both tires?
Limited Slip Differential, has clutch packs.. correct?
custom parts is our perfection.
so if your able to burn both tires on a flat road, then its not LSD? Its a locker type diff?
Because it would go from each tires back and forth and thus create better take off, but not burn both tires?
Limited slip of any type makes sure that one wheel can't spin without the other wheel attempting to do the same.
Whether its a clutch type, locker, viscous, or the mysterious quaife type that my car uses, if you got the power you will smoke both of your drive wheels with any type of LSD.
Its whether you are on slippery surfaces or trying to turn that the different types have their pros and cons.
http://www.quaifeamerica.com/differentials/diffs.htm
Originally posted by "Levi"
But I guess my question is will a open diff spin both wheels?
Guest
Posts: n/a
Is it possible for a one wheel peel to spin both?
Check this out. I have a RWD RX7 with independant rear end with 4:10 gears.
Now according to the factory my car did not come with LSD, only certain models came with LSD..
So if the factory is right I have a non LSD that burns both tires, first and second gear.. WTF is going on, or do all independant rears burn both?
I even had to get certain fluid for the rear because it has clutch packs, but yet its non LSD..
All I can say is I do not have to go into reverse to smoke the tires.
