v8 turbo questions?
everyone reading this should know that i'm stupid when it comes to turbo setups...i know the basics and thats about it...and i understand general concepts when discussing how boost works.
now, with turbo v8's...these have to be twin turbos, right? would this be a twin turbo setup where one turbo is smaller than the other to have staggered boost at different rpms? or is there a way to run a single turbo...
thanks, cause i've just heard of a few turbo v8's...namely a turbo corvette that was featured in car and driver a while ago.
thanks, chet.
thanks, chet.
You could do a single turbo setup but it will require alot of piping. You would be better off going with twin turbo. They dont have to be the same size, but most guys use the same size and scrafice lag for more air flow you would get with two bigger turbos.
Guest
Posts: n/a
\^/h47 y0u 4|23 |23f3|2|21|\|g 70 15 53qu3|\|714l 7\^/1|\|5. 7|2u3 7\^/1|\|5, l1k3 7h053 0|\| 7h3 300z>< 77 u53 7h3 54m3 7u|2b0, 0|\|3 f0|2 34ch b4|\|k. 7h475 7h3 \^/4y y0u'd \^/4|\|7 70 g0 f0|2 3453 0f 3><h4u57 m4|\|1f0ld plumb1|\|g.
I don't quite think you got the sarcasm there buddy..
Originally posted by "Strokd85"
ummm, no.. I believe it's a little larger than that.. (if you are referring to either of the two mustangs)
