veilside 350z
Old Oct 27, 2002 | 11:13 PM
  #21 (permalink)
DETriment's Avatar
Get off my lawn
thats a sexy car, got spanked by one a few days ago
-Nate-
[xbox360]DETrimentS14[/xbox360]
Old Oct 28, 2002 | 06:52 AM
  #22 (permalink)
Adam12's Avatar
Nohatch2000
________________________
Old Oct 28, 2002 | 04:55 PM
  #23 (permalink)
98intrigue's Avatar
single and ready to mingl
:o now that looks badass...i love the new 350z. saw a silver one at my school tonight. it was the track model. first time ive seen one with that package.
Ryan - 2010 40th Anniversary 370Z
First top mount single turbo 370Z - 506rwhp @ 11psi
Top mount single turbo build thread
Old Oct 29, 2002 | 04:38 PM
  #25 (permalink)
steve's Avatar
madpom
here's one more
Old Oct 30, 2002 | 08:11 AM
  #28 (permalink)
Matt Vassallo's Avatar
lifelong learner
what f'ing dumbasses
lets put a holein a perfectly good hood for a air heater.
rest in peace tim.
Old Oct 30, 2002 | 08:44 PM
  #30 (permalink)
civicracer901's Avatar
B16ACRX
Name
Cam Design
Orientation
Cylinders / Configuration
Block / Head Composition
Displacement (liters)
Horsepower
Torque (lbs/ft)
Bore & Stroke (mm)
Compression Ratio (:1)
Maximum Engine Speed
Induction System
Valvetrain
Engine Cover
Engine Mounts (3 mounts per vehicle)
Recommended Fuel
Emissions System
Emission Certification Level
Exhaust
VQ35DE
DOHC
Longitudinal
V6 w/ Continuous Variable Valve Timing Control System (CVTCS) & Molybdenum coated pistons
Aluminum/aluminum
3.5L
287 @ 6,200 RPM
274 @ 4,800 RPM
95.5 & 81.4
10.3
6,600 RPM
Sequential multi-point electronic fuel injection
4-valves-per-cylinder
Standard
2 liquid filled; 1 rubber
Premium unleaded
Closed loop feedback system w/ 3-way catalyst
LEV
Dual (single each side)
Electrical
Ignition System
Electronic, Nissan Direct Ignition System (NDIS)
Starter
1.4KW Reduction
Alternator
110 Amp.
Battery
12 Volt
Transmission and Drive System
Drive configuration
Mid-mounted front-engine / rear wheel drive
Transmission Type 6-speed manual
5-speed auto w/ manual mode
Standard (Base, Enth, Touring 6MT, Track)
Standard (Touring 5AT) Optional (Enth)
Gear Ratio
1st
2nd
3rd
4th
5th
6th
Reverse
M/T A/T
3.794 3.540
2.324 2.264
1.624 1.472
1.271 1.000
1.000 0.834
0.794 N/A
3.446 2.370
Final Drive Ratio
3.538 3.357
Drive Shaft
Carbon Fiber Reinforced Plastic (CFRP)
Viscous-Limited Slip Differential
Standard on all models but Base
Vehicle Dynamic Control
Standard on Perf, Touring 6MT and Track models
Brakes
Standard (Standard on all except Track)
Front Type
Rotor size diameter and thickness (in.)
Vented Disc, 2 caliper pistons
11.65” x .95”
Rear Type
Vented Disc, single caliper piston
11.50” x .63”
Brembo (Standard on Track)
Front Type
Vented Disc, 4 caliper pistons
12.76” x 1.18”
Rear Type
12.68” x .87”
Brake Assist
Standard
Brake Control
Power-assisted (vacuum)
ABS
Number of Wheels
Number of Channels
Number of Sensors
Standard
4
4
4
Electronic Brake force Distribution (EBD)
Standard
Parking Brake
Hand operated along left side of center console
Steering
Type
Engine speed sensitive power rack-and-pinion
Power Assisted
Standard
Overall Ratio
15.9
Turns (lock to lock)
2.6
Turning Diameter (curb to curb, in feet)
35.33
Turning Diameter (wall to wall, in feet)
37.27
Steering Wheel
Tilt
Telescopic
3-spoke design w/ air bag
Manual
N/A
Suspension
Front
Front Strut Tower Bar
Stabilizer Bar
Independent multi-link aluminum suspension
Standard
Standard
Rear
Integrated Strut Tower Brace
Stabilizer Bar
Standard
Standard
Body / Chassis
Type
Unibody
Materials (primary)
Corrosion resistant and high strength steel
Hood
Aluminum
Rear Hatch
Steel
Exterior
Wheels & Tires Base Enth.
Perf.
Track
Touring 5AT
Touring 6MT
Wheels
Aluminum-alloy (7-spoke) FR: 17”x7.5” RR: 17”x8”
S
S
N/A
N/A
S
N/A
Aluminum-alloy (6-spoke) FR 18”x7.5” RR: 18”x8”
N/A
N/A
S
N/A
N/A
S
Super light Aluminum-alloy (6-spoke) FR: 18”x8”
RR: 18”x8.5”
N/A
N/A
N/A
S
N/A
N/A
Tires
Bridgestone Summer tires - Front 225/50R17 94W,
Rear 235/50R17 96W
S
S
N/A
N/A
S
N/A
Bridgestone Potenza RE 040 Summer Tire –
Front 225/45R18 91W,
Rear 245/45R18 96W
N/A
N/A
S
S
N/A
S
Spare Tire
Temporary (steel) Non-Brembo equipped models
Temporary (steel) Brembo equipped Track Package
S
N/A
S
N/A
S
N/A
N/A
S
S
N/A
S
N/A
Location
Trunk
Lights
Headlights
Halogen Headlamps
Flush mounted, Low: xenon HID, Hi: Halogen
S
N/A
N/A
S
N/A
S
N/A
S
N/A
S
N/A
S
Interior
Seating
Base Enth.
Perf.
Track
Touring 5AT
Touring 6MT
Capacity
2-seater
Sport Seat Cloth
S
S
S
S
N/A
N/A
Leather
N/A
N/A
N/A
N/A
S
S
Type
Bucket
Heated Seats
N/A
N/A
N/A
N/A
S
S
Driver Seat Cloth – 6-way manual
S
S
S
S
N/A
N/A
Driver Seat Leather – 4-way power, 2-way manual
N/A
N/A
N/A
N/A
S
S
Passenger Seat Cloth – 4-way manual
S
S
S
S
N/A
N/A
Passenger Seat Leather – 2-way power
N/A
N/A
N/A
N/A
S
S
Memory System
N/A
Passenger seat back fold down function
S
Seat back pocket (passenger seat)
S
Audio
Head unit and speakers
160W AM/FM/CD w/ 6 speakers (w/ digital clock)
S
S
S
S
N/A
N/A
240W Boseฎ audio with cassette/6CD in-dash/AM/FM/CD changer control (w/ digital clock)
N/A
N/A
N/A
N/A
S
S
Radio Data System (RDS), Bose only
N/A
N/A
N/A
N/A
S
S
Bose AudioPilot™ noise-compensation, Bose only
N/A
N/A
N/A
N/A
S
S
DVD navigation system
N/A
N/A
O
O
O
O
Instrumentation
Meters/Gauges
Speedometer
Tachometer
Coolant temperature
Fuel level
LCD dual trip odometer
Standard
3-Bay Gauges
Drive computer
Tire pressure monitor (Perf, Track, Tour 6MT)
Oil pressure gauge
Voltmeter
Oil temperature
Standard
Indicators
Clock
M/T shift up timing indicator (light)
A/T indicator
Cruise Control
Overdrive off
TCS off
VDC off
Standard
When equipped with 6MT
When equipped with 5AT
N/A with Base model
N/A
Enth, Tour 5AT
Safety and Security
Passenger Restraint Systems
Air bags (SRS)
Driver (dual stage with seat belt sensors)
Passenger (dual stage with seat belt sensors)
SRS side & curtain air bags, driver/passenger
Standard
Standard
Optional
Outboard seat belts, front
3-point (ALR/ELR for passenger, ELR for driver)
Seatbelts with pretensioners and load limiters
Standard
Tether anchorage
Standard
Power window lockout button
Standard
Passive Safety
Front crumple zones
Hood buckling creases and safety stops
Rear crumple zones
Body side reinforcements
Shift interlock system AT
Clutch interlock system MT
S
Security
Steering wheel locks when key is removed
Vehicle security system
Immobilizer
S
Dimensions
Exterior (inches)
Wheelbase
104.3
Overall length
169.6
Overall width
71.5
Overall height
51.9
Tread width
Front
Rear
60.4
60.8
Coefficient of drag (Cd)
0.30/0.29 Track model
Interior (inches)
Head room
38.2
Leg room
42.6
Hip room
53.9
Shoulder room
53.6
Cargo volume
VDA rating
SAE rating
8.3 cubic feet
6.8 cubic feet
Weights
Base Enth
Perf
Track
Tour 5AT
Tour 6MT
Curb (pounds) MT
AT
3,188
3,197
3,210
3,217
3,225
3,239
3,247
Weight distribution (%) Front/Rear
53/47
GVWR
3815
Volume (cubic feet)
Passenger compartment
50.5
Cargo
6.8
Total
57.3
Fuel Economy
City
TBD
Highway
TBD
Classification
2-door coupe
WEAK!!! weird how that came out but you can match
