NA Backpressure?? Yep sure is.
Old Oct 10, 2002 | 03:36 PM
Bob22b's Avatar
Default NA Backpressure?? Yep sure is.
So on NA cars what's the deal with them creating more torque on the lowend when they have a restrictive exhaust?
I understand they will make a lot more power up top if you get rid of the exhaust but then you will lose low end power. I have been hearing a lot about the lack of backpressure will make you lose low end torque, but how does this really happen?
What's the real working of this loss of power? I'm looking for one of those insightful lengthy responses!
Old Oct 10, 2002 | 06:13 PM
0HP930's Avatar
Guest
I will keep this rather short and simple.
Its all about what the cam's exhaust profile is set up for.
Many cam profiles use the momentum of the flow of the exhaust through the header to help scavenge gasses from the cylinder.
When you dramatically change back pressure you also change the flow characteristics of the gas flow through the header which can completely disrupt the flow dynamics the cam is designed for.
There is nothing wrong with very low back pressure as long as you have a cam and the proper header geometry to take advantage of it.
The problem is that most streetable cams are not set up for the flow dynamics of a straight header opening to the atmosphere.
