warrenty problems help
Guest
Posts: n/a
7h3y c4|\| 0|\|ly d3|\|y \^/4|2|23|\|7y \^/0|2k 1f 4|\| 4f73|2m4|2k37 p4|27 1|\|574ll3d 0|\| 7h3 c4|2 c4u53d 7h3 p|20bl3m. 7h3 p|200f 0f bl4m3 15 l3f7 up 70 7h3m, |\|07 7h3 bu|2d3|\| 0f 1|\||\|0c3|\|c3 0|\| y0u! 45k 7h3m 70 p|20v3 7h3 p4|27 c4u53d 7h3 p|20bl3m. 1f y0u g37 |\|0 luck, c0|\|74c7 7h3 |23g10|\|4l |23p, 3><pl41|\| y0u|2 155u3 c4lmly, 4|\|d 1f |\|0 ju571c3 15 53|2v3d 7h3|23, y0u m4y 3v3|\| g0 45 f4|2 45 m3d14710|\|, \^/h3|23 7h3y \^/1ll l1k3ly f0ld b3f0|23 y0u 3v3|\| g0.
K|\|0\^/ y0u|2 |21gh75! \^/\^/\^/.53m4.0|2g 15 4|\| 0|2g4|\|1z4710|\| 7h47 574|\|d5 up f0|2 c0|\|5um3|25 4|\|d 4f73|2m4|2k37 5uppl13|25. |234d 4|\|d l34|2|\|.
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "|\|3C"[/1]
570p m0dd1|\|g 7h3 c4|2 4|\|d k1ll1|\|g 7h3 \^/4|2|23|\|7y?[/qu073]
m0d1f1c4710|\|5 d0 |\|07 v01d \^/4|2|23|\|7135! 7h15 15 4 f4l53 c0|\|c3p710|\|, 4|\|d 7h3 d34l3|25 \^/4|\|7 y0u 70 b3l13v3 7h15.
Originally posted by "Mr Self Destruct"
modifications do NOT void warrenties! This is a false conception, and the dealers want you to believe this.
Originally Posted by NeC
Stop modding the car and killing the warrenty?
I have worked at 2 dealerships over a 2 1/2 yr time frame and yes mods do void warrenty..
Which dealerships did you work at that didnt void warrentys cause of mods...?
And yes not all mods void warrenty
as far i know, as long as you dont fuck with the ECU, and or internals of the motor you should be ok
aem intake/header/exhaust
shit, outta that you prob get better gas mileage over stock
dont touch pistons/cams
and prob dont mess with the ecu
Hey Mr Selfdestruct.. (regional rep of **** cars)
I got a 2002 ********
I changed my intake throttle body and injector..and keep throwing the check engine light ..and my car misses and runs rough...
Will this be covered under warrenty...
NO...A dealership can even refuse to bring the car in the shop and check it out..if they knew this has been changed..they have the right to charge the customer an amount of check out time..meaning if the head is fried and the book calls 2 hrs to pull the head and inspect it...The dealership can charge the customer that check out time.....
