MSD SUCKS!!!
Old May 20, 2002 | 11:35 AM
Chismoe's Avatar
Craving Boost
I had a guy that works for a Domestic mag tell me the same thing. They work but their technology and design is archaic. he said to check out some other ignition...drawing a blank at the moment. I know he said HKS was really good but $$$.
Old May 20, 2002 | 11:38 AM
civicracer901's Avatar
B16ACRX
Jacbos i heard is really good overall ! Thats what i use if i were you . MSD does sux!! i agree.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old May 20, 2002 | 11:41 AM
mpbiv's Avatar
Rod Bearing Eater
I am not trying to question your credibility but it might help if you give a better reason why no one should use their stuff. Maybe a example of the problems you have had with them. Giving a example would back up your argument a lot better
I have no experience with MSD products and am curious to know more about why you have this opinion
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old May 20, 2002 | 11:46 AM
dsonik1's Avatar
Professional Drif-Tater..
doesnt jegs have one as well?
Doogie: "Hey did you notice I was tandem with you slidin around that corner?!"
Sonik: " Cool! Did it look hot?, cause if you ever get that close to f'ckin my car up again.... the fuzzy balls hangin from my mirror will be yours
Import Corner Inc.
6432 massachusetts ave
new port richey,fl 34653
1-888-520-9601
GO TO:www.importcornerinc.com
MYSPACE
www.myspace.com/bmwsonik
Old May 20, 2002 | 11:55 AM
Mr 2's Avatar
New Member
I had some problems when I first install my MSD system on my Mr2. It turned out to need a special ignition module convertor($15) to work with my car. So I put one in and go on my way. Then I shut the car off and it wont start...turns out my MSD was alittle too close to the engine and the heat would affect it. So I move it and only get the wont start problem occassionally. It turns out I had the wrong ignition module convertor (or whatever the thing is) and it would mess with my FI signals replaced that and havent touched it in years runs great.
Old May 20, 2002 | 12:35 PM
dan's Avatar
dan
Get the fuck off my lawn
their 72lb injectors work very well
as do the 50 and 60lb ones
Old May 20, 2002 | 02:09 PM
88EFSiR1J1's Avatar
ignition systems all together suck.
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
