maf coupling ???
Old Jan 20, 2010 | 10:26 PM
  #21 (permalink)
Graves's Avatar
try goodyear rubber downtown st pete?
Old Jan 21, 2010 | 12:16 AM
  #22 (permalink)
Nycist's Avatar
NY Till I Die....
i found this literally after 7 secs of google search......try a lil harder next time please.
Dr. Gas Exhaust - Store - 2" Round to Oval Transitions
Originally Posted by Lime_Green_Hatch
$350,000 in 2 years... and all they had to show for it was some shitty hondas, lol.
R.I.P. Steven Daniel Berry a.k.a. Bush
Old Jan 21, 2010 | 08:45 AM
  #23 (permalink)
mikiemike75's Avatar
mikiemike75
i seen this also myself but it needs to be a 4 wide oval by about 2 tall and then transiton intio a 2.5 coupling so it still wont work... trust me i have tried a little harder... ive called samco hoses greddy injen and abunch of places around here but good thinking and the goodyear store i will try that...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 21, 2010 | 02:16 PM
  #24 (permalink)
GsT Racer's Avatar
back in a 4g63
Just keep it where its supposed to be instead of fabbing up stupid crap. You're not going to see any amazing results by putting your stock maf just before the tb.
Just put the maf in the original spot, save up $200-$250 and buy yourself the gm maf and translator. Then make sure you know someone who can tune the translator right.
If you're running a 2.0 stroker(which i dont know how you can do that with a factory 2.0 block facepalm.jpeg), do it right.
Old Jan 21, 2010 | 02:25 PM
  #25 (permalink)
mikiemike75
not running a factory 2.0 block im running a slowboy rcn stg1 stroker kit setup... and that explains the reason for not having money for a maf right now... and actually if youve ever done it you recieve alot better readings with it after the intercooler you get alot better air temp readins and how much air flow there really is...
hp~5!! trq-4!!
doing work!!!!!!
Old Jan 21, 2010 | 05:56 PM
  #26 (permalink)
GsT Racer's Avatar
back in a 4g63
so youre going to run a 2.3 then. and im assuming you are swapping out the stock motor for a 6 bolt?
Old Jan 21, 2010 | 07:34 PM
  #27 (permalink)
mikiemike75
so with any luck i should have the coupling i need... i found one from a 05+ mustang gt and it works perfect... should be coming in one day next week...
hp~5!! trq-4!!
doing work!!!!!!
