SVT Focus vs Sentra SE-R SpecV
These two seem to be two natural competitors with every manufacturer trying to get our (the young enthusiasts) money the hot ticket seems to be aiming under $25k and running 15s.
These two are within $1000 7lbs 10hp .5 second in the 1/4 .03g skidpad same tires both 6spds... Should be interesting.
Heres the rundown on the two sub-$18k cars:
2002 FORD SVT FOCUS
Estimated Price: $17995 (includes destination and delivery)
Engine
Type : Inline four iron block and aluminum head
Valvetrain: DOHC four valves per cylinder
VCT variable intake cam timing
Displacement: 1988 cc
Bore x Stroke: 84.8mm x 88.0mm
Compression Ratio: 10.2:1
Claimed Crank Hp: 170 hp @ 7000 rpm
Claimed Crank Torque: 145 lb-ft @ 5500 rpm
Measured Wheel Hp: 150 hp @ 6350 rpm
Measured Wheel Torque: 132 lb-ft @ 5300 rpm
Redline: 7250 rpm
Drivetrain
Layout: Transverse front engine front-wheel drive
Transmission: Six-speed manual
Gear Ratios: 1: 4.44:1 Final Drive: 2.88:1
2: 2.67:1 2.88:1
3: 1.33:1 4.25:1
4: 1.08:1 4.25:1
5: 1.33:1 2.88:1
6: 1.08:1 2.88:1
Differential: Open
EXTERIOR DIMENSIONS
Curb Weight: 2750 lbs.
Weight Distribution F/R: 61/39
Overall Length: 168.1 in.
Wheelbase: 103.0 in.
Overall Width: 66.9 in.
Track F/R: 58.8 in.
Height: 56.3 in. Suspension
Front: MacPherson strut
Rear: Multi-link Control Blade with one main trailing link with integrated hub one main laterallink one lateral toe-control link and one lateral camber control link
Brakes
Front: 11.8-inch vented disc single-piston caliper
Rear: 11.0-inch solid disc single-piston caliper
Wheels and Tires
Wheels: 17 x 7-inch aluminum
Tires: 215/45R-17 Continental Conti SportContact
Performance
Acceleration
0-30 mph: 3.3 sec.
0-60 mph: 7.9 sec.
30-50 mph: 2.9 sec.
50-70 mph: 4.1 sec.
Quarter Mile time: 15.8 sec.
Quarter Mile speed: 89.5 sec.
Handling
Lateral Grip (200ft skidpad): 0.85g
Slalom Speed (700ft slalom): 68.7 mph
Braking
60-0 stopping distance: 116 ft
2002 NISSAN SENTRA SE-R SPEC-V
Estimated Price: $16999
Engine
Engine Code: QR25DE
Type: Inline four aluminum block and head
VTC variable intake cam timing
Displacement: 2488cc
Bore x Stroke: 89.0mm x 100.0mm
Compression Ratio: 9.5:1
Claimed Crank Hp: 175 hp @ 6000 rpm
Claimed Crank Torque: 180 lb-ft @ 4400 rpm
Measured Wheel Hp: 141 hp @ 5750 rpm
Measured Wheel Torque: 150 lb-ft@ 3750 rpm
Redline: 6200 rpm
Drivetrain
Gear Ratios: 1: 3.417:1
2: 1.944:1
3: 1.258:1
4: 0.947:1
5: 0.773:1
6: 0.630:1
Final drive: 4.429:1
Differential: Helical limited slip
Chassis
Chassis Code: B15
Exterior dimensions
Curb Weight: 2743 lbs
Weight Distribution F/R: 62.2/37.8
Overall Length: 177.5 in.
Wheelbase: 99.8 in.
Overall Width: 67.3 in.
Track F/R: 58.1 in./57.3 in.
Height: 55.5 in.
Suspension
Front: MacPherson Strut
Rear: Multi-Link Beam (twist beam axle with
two trailing links and one Scott-Russel lateral
locating link)
Brakes
Front: 11.0-inch vented discs
single-piston sliding calipers
Rear: 9.1-inch solid discs
Wheels and Tires
Tires: 215/45ZR-17 Continental Conti SportContact
Performance
Acceleration
0-30 mph: 3.1 sec.
0-60 mph: 7.4 sec
30-50 mph: 2.5 sec.
50-70 mph: 3.8 sec.
Quarter Mile time: 15.4 sec.
Quarter Mile speed: 90.8 mph
Handling
Lateral Grip (200ft skidpad): 0.88g
Slalom Speed (700ft slalom): 70.2 mph
Braking
60-0 stopping distance: 126 ft
Ive yet to drive either but the SE-R looks better on paper despite the hatch appeal.
*note: I bolded the differentials perhaps the most important difference.
2002 FORD SVT FOCUS
Engine
Redline: 7250 rpm
Drivetrain
2: 2.67:1 2.88:1
3: 1.33:1 4.25:1
4: 1.08:1 4.25:1
5: 1.33:1 2.88:1
6: 1.08:1 2.88:1
Differential: Open
EXTERIOR DIMENSIONS
Track F/R: 58.8 in.
Brakes
Wheels and Tires
Performance
Acceleration
0-30 mph: 3.3 sec.
0-60 mph: 7.9 sec.
30-50 mph: 2.9 sec.
50-70 mph: 4.1 sec.
Handling
Braking
Engine
Engine Code: QR25DE
Redline: 6200 rpm
Drivetrain
2: 1.944:1
3: 1.258:1
4: 0.947:1
5: 0.773:1
6: 0.630:1
Chassis
Chassis Code: B15
Exterior dimensions
Wheelbase: 99.8 in.
Height: 55.5 in.
Suspension
locating link)
Brakes
Wheels and Tires
Performance
Acceleration
0-30 mph: 3.1 sec.
0-60 mph: 7.4 sec
30-50 mph: 2.5 sec.
50-70 mph: 3.8 sec.
Handling
Braking
ones a Ford ones a Nissan I think you get the idea
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
14.729 @ 94.79
I already heard some bad things about the Nissan like it being horribly inconsistant from car to car power level wise. Lets hope that they got that issue resolved otherwise it is another 99 Cobra fiasco all over again. Id still sport the SVT Focus any day blue of course.
They seem to be pretty consistant 141whp 150 wtq of course the inconsistancy is that its rated at 180/180. Cockpit feel will be a big factor I think.
Here you go craig:
Here you go craig:
I was very impressed with my SPEC-V test drive.
Very comfortable interior yet very sporty.
Nice looks & 4 doors were good.
I hate trying to tote people around without 4 doors.
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
-Kris
Current Projects:
72 2wd Blazer
2013 BMW X5
2008 Chevy TBSS awd
I must say the Focus is starting to grow on me..how much does a base model run?
CHRIS
The next time you can't find a designated driver, just park in a tow a way zone!!
CHRIS
