need help plz
Old Aug 16, 2009 | 11:37 AM
aids@ftl's Avatar
Exclamation need help plz
ok soo im driving down the road... i get to about 50mph...car shifts(as always).. then as i get to about 60 my engine bogs down and i have no power...i could stomp on it and not increase in speed.... even if i put her in neutral i cant rev it...
ive read somewhere it might be a fault ignition??
is that right plz help me figure out what to to
oh btw its a car borated 305
DuBsTeP = LiFe
I like my cars clean
But my ladies CLEANER
Old Aug 17, 2009 | 06:37 PM
Thatguysstuff's Avatar
Hey its that guy!!
Well check for the obvious.. spark? fuel?
Old Aug 19, 2009 | 02:39 AM
markstheman365's Avatar
cant slide
my old car did something really similiar. except it would rev really slowly. check the ground wire on the engine. clean it up. also check injectors like he said^
contact admin@tamparacing.com to advertise on here.. - mod
Old Aug 19, 2009 | 04:50 AM
Ares's Avatar
ground wire,fuel pump, dizzy, spark plugs.start with the cheapest which would be plugs and wires then move up from there hope this helps also is it throwing back any codes ?? perhaps the carb is dirty try spraying some carb cleaner in there or rebuild it.
there are those of us who choose to fight and those of us who choose to stand on the fence and watch not wanting to get involved. but we all search for a small measure of inner peace but few of us ever find it
Old Aug 19, 2009 | 06:23 AM
RoadRacer's Avatar
Turn 7 at Sebring
If this is your el camino, you should post this in the GM section.
My guess is vapor lock, but take it to a mechanic if you can't take the time to trouble shoot the issue.
Patrick -
Old Aug 26, 2009 | 09:02 PM
Sometimes the ECU won't let the engine hurt itself.
It pops a code and the engine won't rev over that. Do you have a check engine light? Do you have the device to reset engine codes?-Bob
Old Aug 27, 2009 | 01:06 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
I dont think carb'd 305s came with ECUs...unless you count TBI.
ASE: Brakes
Old Sep 2, 2009 | 03:37 PM
aids@ftl's Avatar
it ended up being the inline fuel filter... my gas tank has a lot of rust init=[
but thanks for the ideas...i still need to change the plugs
DuBsTeP = LiFe
Old Sep 7, 2009 | 05:01 AM
Looks like the responses covered everything it might be.
Glad you found it, and thanks for posting back, so we could all learn from it.-Bob
