Car issue question
i know it sounds simple...but make sure you have a good connection to your battery. i've done it before and thought it was several things...then finally i started with the simplest thing and tada.
Turns out its the starter... go figure, i dunno how that would cause it to run really rough though. But i got it push started and it ran fine. So looks like im in replacing that.
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
Im thinking if the starter caused a electrical issue that would cause the problem with spiting and sputtering like it did. Although the #1 spark plug was flooded to high hell so that may be more of the issue. Its for my 96 sentra, not rx7. ill see if it fixed it.
