Mass air -> speed density
Speed density uses manifold absolute pressure and an ambient air temp sensor and calculates the density of the air along with throttle position...and gives that value to the computer for fuel and ignition timing/delivery.
Mass air takes a direct value of the incoming air charge and the most common method is the hot wire a wire is set inside the MAF and put into the airflow the wire is then energized..the more air that flows through..the colder the wire gets...and resistance of electricity is directly proportional to the wires temp so the computer knows how much air is flowing based ont he resistance of the wire.
Not so common is the flapper door where the more air that goes through pushes open a flap.
Mitsu..karman vortex in the dsm...some kind of techno voodoo shit that measures the vortices produced by incoming air...black magic.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
speed density sucks for turboes
stick with your MAF you wont spend 99.9999999% of your time tuning your ride and you car wont run good one day and then run like ass the next
Sabri
94 4 Door Sentra w/
GTi-R SR20DE-T
12.836 @ 112.98mph
Tampa, Fl
Sabri
94 4 Door Sentra w/
GTi-R SR20DE-T
12.836 @ 112.98mph
Tampa, Fl
Originally posted by Boosted Z31
speed density also useds manifold pressure to sense the engine load
I siad that manno....thats why we have map sensors..manifold absolute pressure.
10' 1198S
09' Ninja 500R
09' Stella
10' 1198S
09' Ninja 500R
09' Stella
