My camber is so bad!!!
Old Jan 17, 2002 | 06:37 PM
B16aEG's Avatar
I lowered my car 2.25 I have a 93 Honda civic CX and i just bought new tires about a month and a half ago. And i need to buy new ones already I bought a camber kit But i was just wondering if its a bitch to put on and can i adjust it without having to get an alignment so my tires will be straight instead of slanted like a mofo.
I went to school with my 3inch Thermal exhaust in my 93 civic hatch b-c i had no where else to put it for the time being , Well this kid walks up and looks in the car and say's " Is that an exhaust" and i say yah. He says" doesnt it get really hot in there?"
Old Jan 17, 2002 | 07:03 PM
Tony's Avatar
Senior Citizen
Anytime you mess with the suspension you should get an alignment. When you get the alignment they can tell you if the camber is within specs too. You can fix the front camber with a camber kit....but the rear you can do some ghetto engineering with some longer bolts and washers. Camber kits shouldnt be too terribly hard to install...but then when I lowered mine my camber wasnt bad enough to need one. But Im no expert just putting my $0.02
10' 1198S
09' Ninja 500R
09' Stella
Old Jan 17, 2002 | 07:34 PM
low99civic's Avatar
The thing that will wear out your tires faster than camber is if the toe setting is out. Meaning that your tires arent pointed straight ahead. With a camber kit it is easy to set the camber by eye without the use of an alignment machine but to read and set toe you will nee to have a professional align it. If you live near the Sarasota area I can do that for you.
samecraig
Feb 10, 2001 05:45 AM
VDormCRX
Feb 4, 2001 11:42 PM
