Short Shifter and Knob question, what do you think?
Old Apr 18, 2009 | 03:26 AM
tobibeck80's Avatar
Nordschleife addict
Default Short Shifter and Knob question, what do you think?
this may look like a dumb question I admit, but I'm having a realy hard time in a German Forum about that topic.
I (beeing German) consider a short shift as a shorter gear linkage, so you have a little advantage in putting in gears.
I say it has nothing to do with a shorter or short shift knob, does it?
Because all that does is making the shifting harder, not shorter!
I'm asking because everytime the short shift topic appears, people in that Forum say that a "short shift" is the same as a "shorter knob", what I always disagree
When they mean a real short shift, the shorter linkage, they say the German word for it "Schaltwegeverkürzung".
So actualy they use the German and the English word (short shift) for two different things, not even recognizing.
I don't believe that this is right.
So how would you describe a shorter shift knob?
as a "short shift" too?
It's not enough to them when I say that I'm good in speaking English and that I know what I'm talking about, I need clear statements by English speaking people
Old Apr 18, 2009 | 05:53 AM
It's all words.
A general principle is that the longer the rod is below the floor,
the more effort is required to shift, but the distance to move the lever will be shorter above the floor....
An early VW short shifter trick was to use the verticle rod from a transporter and cut the top part of the rod off to the same length as the regular VW rod. The bottom was longer than the standard bug, so the shift was a shorter distance for your hand to move to get it into gear.
I have installed short shifter kits for Hondas, and the rod is longer below the floor....slightly more effort, but less distance to move your hand to get it into gear.-Bob
Old Apr 18, 2009 | 07:12 AM
'95hatchCivic's Avatar
^boom question answered
