isuzu imark
Old Jan 10, 2002 | 06:23 PM
topichikoludo's Avatar
where can I find the specs 4 89 isuzu imark rs???
I'm not running in circles
I'm just cutting corners
Old Jan 11, 2002 | 10:12 AM
j99jm's Avatar
1989 I-Mark RS
General Information
Manufacturer
Isuzu Motors Ltd. Fujisawa Japan
Importer
American Isuzu Motors Inc. Whitier California
Body Style
4-passenger two door hatchback or four door compact sports sedan
Drivetrain Layout
Front Engine Front Drive
Body/Frame
Uni-body
Price
$9359-11068
Options
Recaro seats
Typical Market Competition
Mazda 323 GTX Mitsubishi Mirage Turbo Volkswagen GTI 16V
Dimensions
Wheelbase
94.5 in / 2400 m
Track
Front
55.4 in / 1406 mm
Rear
54.6 in / 1386 mm
Length
157.9 in / 4011 mm
Width
63.6 in / 1616 mm
Height
54.1 in / 1375 mm
Ground Clearance
Curb Weight
2167
Weight Distribution
65/35
Cargo Capacity
16 cu ft / 29.7 cu ft
Fuel Capacity
11.1 gal
Weight/Power Ratio
17.34
Engine
Type
Inline 4 liquid cooled cast iron block cast aluminum head
Bore x Stroke
3.15 in x 3.11 in / 80.0 mm x 79.0 mm
Displacement
97 ci / 1588 cc
Compression Ratio
9.8:1
Valve Gear
DOHC 4 valves per cylinder
Fuel/Induction System
Electronic Multipoint EFI
Horsepower
125 HP @ 6800 RPM
Torque
102 lb/ft @ 5400 RPM
Horsepower/Liter
78.72
Maximum Engine Speed
7800 RPM
Recommended Fuel
Unleaded Regular
Driveline
Transmission Type
Five speed manual
Gear Ratios
First
3.727
Second
2.043
Third
1.448
Fourth
1.027
Fifth
.829
Axle Ratio
Final Drive Ratio
4.117
Chassis
Suspension
Front
Independent MacPhereson struts with lower control arm coil springs anti-roll bar
Rear
Independent shock absorber trailing arm with coil springs anti-roll bar
Steering
Type
Rack and pinion power assisted
Ratio
16.1:1
Turns Lock to Lock
2.88
Turning Circle
32.8 ft
Brakes
Front Type/Diameter
Vented discs 9.02 in
Rear Type/Diameter
drums 7.09 in
Anti-Lock
Not available
Wheels and Tires
Wheel Size
14 x 5
Wheel Type/Material
Cast alloy
Tire Size
185/60R14
Tire Manufacturer and Model
Bridgestone Potenza RE88
There ya mang hope that helps ya!
Old Jan 11, 2002 | 10:45 AM
Robster's Avatar
damn thats scary you know all that shit.
Robster
You have now seen the entire internet good bye.
Old Jan 11, 2002 | 10:48 AM
dscivicdx's Avatar
TR Balla Donor Supreme
Originally posted by "Someone"
Robster
Old Jan 11, 2002 | 11:04 AM
b16a2pwr's Avatar
ALLJDM
everything that you ever wanted to know is on the internet!
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Jan 11, 2002 | 12:13 PM
b16a2pwr's Avatar
ALLJDM
Exactly....and Im an information studies major.....so I can find you information on ANYTHING you wanna know!
AIM: jasonbadler
813.508.PLAN (7526)
Old Jan 11, 2002 | 12:14 PM
b16a2pwr's Avatar
ALLJDM
exactly!
AIM: jasonbadler
813.508.PLAN (7526)
Old Jan 11, 2002 | 12:59 PM
hehe where can we find your pic or phone # integra girl?
Old Jan 11, 2002 | 01:00 PM
Old Jan 11, 2002 | 01:08 PM
Robster's Avatar
Im sure a certain aussy on this board would be willing to give it to ya along with slap upside your head.
Robster
