Snapped bolt head....help?
Okay well im running out of ideas i was working on my 83 280zx na and i snaped a bolt off in the block while trying to pull the water pump there is ruffly a half inch hanging out. Ive tried a stud puller with no luck ive also tried to cut a slit in it to see if i can get it out with a screw driver but no luck. Ive been hitting it with pb blaster every chance i get but nothing. I could drill it out but i really dont have enough room between the block and the condensor. Need help asap i dont know what else i can do.
here is a ruff idea how much room i have just no radiator
Try heating it with a propane torch and letting it cool to see if it expands and contracts and breaks the rust bond a bit.
Clamp some vice-grip pliers down on it as tight as possible and whack them with a hammer to "impact" it loose.
Weld a nut to the end and try a socket wrench again to see if the pb blaster has done any good.
the clamps just cut into it it sucks you can see the teeth marks from trying that i cant weld or have a welder i may go out and get a torch but even if i torch it idk how to pull it
Matt
A big turbo stang and a big turbo truck.
put some never seize on some new bollts before you put it back together
Thanks
