Whp Debate
Old Oct 15, 2008 | 08:51 AM
  #21 (permalink)
power2weight's Avatar
-eats the last cookie.
Originally Posted by John
a perfect example is a tale of 2 240sx's, both s14s and both had stock displacement, gearing and same compression ratios. One was a certain silver s14 that was well publicized that made a shade over 600whp, rather narrow powerband. The other was a friend of mine's, not so well publicized, made a shade over 400whp with a great power band. The 400whp car had no issues pulling well ahead of the other car, even with a lot less peak whp.
The question wording sucks, but that is really the only way to compare the 2, same displacement (volumetric efficiency), gearing (torque multiplier), aerodynamics and mass of the 2 cars being compared.
Peak hp certainly has it's place, drag racing and road racers with the right drivetrain can harness a narrow powerband, guys at Bonneville definitely only go for peak power.
Horsepower as seen at the wheels or rather the contact patch is really all that maters. And people need to put more emphasis on torque.
"They must really feed each other to the lions down there........"
Old Oct 15, 2008 | 09:38 AM
  #22 (permalink)
bitemark46's Avatar
Got traction?
the difference is midrange. the FI car will have a lot more of it, and thats where the race is won. Peak whp don't mean shit
midrange is under the curve is it not? You just repeated what I said. I think it depends on the type of power adder. Turbos are more peaky and PD blowers have power from idle. 2 engines, same displacement, and same numbers on the rollers I'd take n/a over FI.
-Mark
98' cobra
Old Oct 15, 2008 | 10:13 AM
  #23 (permalink)
Todd's90's Avatar
0711, USMC
-Mark
your never going to get the same numbers ( hp and torque ) between the same 2 motors one being forced induction and the other being N/A. Your never going to have the torque potential with a N/A car that a forced induction car will have.
1990 GS-T
1990 GST
2004 BMW 325i
Old Oct 15, 2008 | 11:21 AM
  #24 (permalink)
dan's Avatar
dan
Get the fuck off my lawn
john and mark said it best.
numbers are numbers, but the powerband/area under the curve will affect which one would technically "work" better (i.e. - be faster).
if you wanted to get technical, you could take an all motor 300hp car and an FI 300hp car, both with completely different powerbands, but if you were to set up gearing in the car with the smaller powerband, you could probably get them to accelerate the same.
ive always said powerband > peak
and yes i remember that 240 matchup :gordy:
case in point, this is why people make fun of supras, because the way it used to be was you go out and throw $xx,xxx at the car.
the supra would be:
-800 whp peak
-500 whp or more for 1000rpm
and get spanked by a car like this:
-600whp peak
-500whp or more for 3000rpm
not taking into account weight, driver, tire, etc.
