Audio question
Old Oct 9, 2001 | 06:53 AM
stangerang's Avatar
whoopdy fucking do!
OK--- im dretty knowledgeable about audio equipment--i have installed many systems too----anyway --i had to make room in my trunk---i couldnt run my 12s in my big ass box that had two chambers so i made an isobaric (clamshell style) box and am running my two subs at 2 ohms-----i ran them at 2 ohms when they were in seperate chambers---anyway now when i crank it my amp blows the fuse some times(never used to do it)---i was just wondering if anyone knew if there is some type feedback that is sent to your amp when running a speaker out of phase(reverse) because the amps fuse will blow if cranked now and it didnt do that before---and it was always at two ohms--as it is now---
anyone>?????
200 points away from a 300
Old Oct 9, 2001 | 08:22 AM
stangerang's Avatar
whoopdy fucking do!
someone aswer the goddamn question!!!!!!!
Old Oct 9, 2001 | 10:08 AM
Ringo's Avatar
Mr. Spinnies
hey i just wanted to respond to do some post whoring. i have no idea about stereo stuff that is the only thing that i bring to someone to have done for me.
Kill 'em all..
If YOU could do it, you would..
Old Oct 9, 2001 | 10:39 AM
93ex's Avatar
Just Ledoux it!
check your connections again and make sure you didnt run them parrel and wound up droping them down a few ohms. if this continues just run then normal for the time being and break out the paper work for your subs and get the correct wiring directions. or just send me the info and i will figure it out.
Old Oct 9, 2001 | 11:15 AM
stangerang's Avatar
whoopdy fucking do!
Originally posted by "Someone"
they are parallel --im runnig them at 2 ohms---- if i dont it wil suck---one speaker is wired (reverse)--out of phase-- but you must do this to run a clamshell isobaric enclosure--anyway it doesnt really matter if i fix it--it only blows when i put on something that hits really hard---which i rarely do---i was just wondering if anyone might know the problem----P.S. my amp can handle 2 ohms--so thats not the problem.....--thanks for looking though
Old Oct 13, 2001 | 02:53 PM
93ex's Avatar
Just Ledoux it!
By what you describe it shoudlnt matter if you run one sub out of phase or not. If it did it woudl blow all the time..not just when youre bumping. Well it work if it is wired to an individual channel so then ther emight be an issue in your amp..call the amp manufacturer to se eif its supose dot happen liek aprotection mode. try borrowing another amp for just tes tpurposes..
Old Oct 21, 2001 | 05:39 AM
GOTTI's Avatar
OEM Parts Specialist
are the subs DVC or SVC???
Old Oct 21, 2001 | 08:59 AM
TotalEclipse's Avatar
eats yellow snow
what kind of subs are they? Isobaric requires one sub to be out of phase to complete the push-pull sequence. This setup allows the speakers to get more excursion and therefore possibly be using more power (even though you may not necessarily be hearing more sound) this added draw in power could be blowing your fuse. If everything is the same as before with the wiring and it worked fine before I would try upgrading the fuse. what size amp and power wire are you running?
Old Oct 23, 2001 | 05:47 AM
stangerang's Avatar
whoopdy fucking do!
it is two JL audio 12w0s----SVC-----i am running an mtx 280watt amp to them----they are in paralllel for two ohms and onw is out of phase----i had them in individual chambers at two ohms also and never had any problems.....
